Corsair 900D fan configuration
Metro
Hello
How many fans would you use with a Corsair 900D, I will be having it like this
The blue is intake and the red is exhaust
It will be Push and Pull on the radiator at the top
What do you think
Thanks
post-236670-0-57691500-1436820836_thumb.
GPU[Two GTX 980ti Lightnings overclocked]-CPU[Core i7 5930K, 4.4Ghz]-Motherboard[MSI X99 Godlike]-Case[Corsair 780t Black]-RAM[32GB Corsair Dominator 3000Mhz Light bars]-Storage[samsung 950 Pro 512GB, Samsung 850 Pro 1TB and Samsung 850 Pro 512GB]-CPU Cooler[EK Predator 360mm]-PSU[EVGA 1600w T2 Individual cables Red]-Monitor[ASUS PG348Q]-Keyboard[Corsair K70 Red]-Mouse[Corsair M65 RGB]-Headset[sennheiser G4me one]-Case Fans[beQuiet Silent Wings 2]
Exhaust out of the top and rear, intake on front and sides.
^ This
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
If you use pressure optimized fans for the rad, then you should use them as outtakes, simply because they will move less air out of your case than airflow fans.
Your pressure will be still positive and the pressure on the SP fans will even increase which is good for the rad.
So, front -> intake / top and rear -> outtake
To further explain, you should rarely ever use top mounted fans as intake due to the physics of hot air.  Hot air rises so you'd be fighting physics by having intakes on the top.  If you intake in the front the cool air gets pushed in forcing the warm air to the top and back.  You exhaust there and you get a much better scenario for moving air through your case keeping things at a cooler temperature.
Should I get another 4 fans for the side then or is it not needed, I will not be building a full custom loop for it.
Hello
What do you think
Thanks
I would do
front-intake
rear-intake
top-exhaust
side panel-intake (optional, since no custom loop probably not a big deal. 4 intake 3 exhaust is pretty good
edit: primary reason I would do a intake in rear would be for mobo cooling.  watercoolers eliminate the airflow that aircoolers generate around the vrm on mobo and that scares me.  having a intake blowing on that area will help a lot.  exhaust will not move as much air over the area although it will still have some effect
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
I would do
front-intake
rear-intake
top-exhaust
Well then there would not be much air going out of the case because of the static pressure fans on the top
there is 3 fans on top, one of them not going through a radiator. That'll move more than enough air
I am thinking about getting 9 Noctua NF A14 fans for both static pressure and airflow, that should do it, what do you think, is there any better airflow fans
Yeah there should be tons of threads on that topic that'll be more help than i could be. I just got a fractal design venturi and its stupid quiet, great pressure and decent airflow for 15$us. But those threads would be the best resource
