Up to 90C when gaming on Razer Blade?
Chibify
Pretty sure this is not normal but I contacted their support and they said as long as no problems are happening its fine. Still seems too high though.
EDIT: I have only tested it on CSGO and League. Both not that demanding and still super high temps. Even with League on lowest settings, it still was at 90C.
What the CPU or GPU?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
I believe it was the GPU but I am not 100% sure sorry. Both were very high though and I think similar numbers.
What surface is it on when gaming?
Glass
Glass
Well glass is a bad conductor.
Check Linus and hardwarecanucks review they should have the temperature, I'd love to check for you but I don't want to finish my mobile plan
Thats normal for any gaming grade laptop
@Swndlr got any ideas on this?
Mine never gets this hot, I would notice because it would throttle like crazy.
In games like CS that can easily be maxed out, frame rates should be capped so its not just letting the GPU go all out on the game and in return that will ramp up the usage and fan RPM's and temps as a whole.
So i have CS capped at 70 fps and i have tried a cooling pad. The CPU can still go up to 90C and the fans are working hard already. Should i contact razer about this?
Yes that sounds like a problem.
Awesome, I will let you know what they say.
Im curious to hear, as Ive never needed to contact them for any issues before.
They were pretty quick and easy when dealing with some Deathadder issues. I hope the same is for the Blade! Would be a nice bonus if they sent back a 2015 model :D
They wont, that much Im almost sure of.
It gets hot, 90 is quite normal for a gaming laptop internally
http://www.anandtech.com/show/8971/the-2015-razer-blade-review/6
This is what they replied with to my email, "We apologize for the issues you are having with your System. Although the Blade does get warm, if it were ever to enter an unsafe temperature it is designed to shut down. Is the system itself shutting down? Let us know more information regarding the cause of the temperature and if it is shutting off along with filling out the form below and we can see how we would like to proceed with your case."
Get one of those things where you set it on a desk and it has fans under it, lemme find it.
EDIT: Here it is
