This is project Nexus, which I was forced to build after my Corsair CX600M decided to take it's life along with the most of my previous computer in a catastrophic light show.
Please never buy corsair CX series power supplies unless you are on an extreme budget or have a pathological hatred for your components.
Anyway this was built around mid June but I haven't posted it until now because I was banned.
Specs :
Intel i7 4790k
EVGA GTX 970
8Gb Corsair Vengeance
MSi Z97 PC Mate
Samsung 128Gb 850 Evo
WD Blue 1TB
EVGA 750W G2
Corsair H100i GTX
NZXT H440
Windows 8.1 Pro
BenQ XL2420Z
The whole build took about 3-4 hours to do including installing windows.
Average FPS : GTA 5 (Very High)
                      Minimum 48 - Average 62
                         BF4 (Ultra)
                      Minimum 70 - Average 112
                        CS:GO (High) [FPS_MAX 500]
                     Minimum 210 - Average 450
Boots in less than 5 seconds. Time from power off to opening chrome is about 15 seconds
In total the computer costed close to $1300-$1400CAD and $2100-$2200 with peripherals.
144hz master race. 60hz is so 2014. (It's impossible to go back!)
Thanks @thekeemo for helping me find a cheap 4790k
Any questions? Let me know!
I have taken some pictures to document the build process:
PmPvIW0.jpgQlFwmYh.jpgI6oXDG3.jpgnrryZr8.jpgQuybeDY.jpgMyqgX9m.jpgSBF7sGf.jpgKc5ecQt.jpggS11uJp.jpg1aZEos3.jpgjP5JjZM.jpg
Intel Core i7 9700k - EVGA FTW GTX 970
https://linustechtips.com/topic/400702-project-nexus/
cool
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/400702-project-nexus/#findComment-5401830
You ought to see if corsair will replace any of that shit if the psu was under warranty.
I'm sorry for your previous loss, looks great though, did the old thing get covered by warranty at all?
Called support. They will only replace the power supply and not the components, but I declined because this is the 3rd time a CX series PSU has killed me or a friend's computer
https://linustechtips.com/topic/400702-project-nexus/#findComment-5401834
If you dont mind spending a couple bucks on postage and the supply is not under warranty or you cant care to get it replaced, you should mail it to me and I can do a complete electrical autopsy and figure out why the fourth of july got released in the power supply. I would document everything here as well as the EEVBlog fourums. PM me if interested.
https://linustechtips.com/topic/400702-project-nexus/#findComment-5401863
LOOOOL
It pisses me off even more since people have started making high-end builds with that 500W EVGA 80+ PSU, which is even worse then the Corsair CX
"Rawr XD"
https://linustechtips.com/topic/400702-project-nexus/#findComment-5401869
Threw it out already, it happened at the start of June. I probably should have taken pictures :/
https://linustechtips.com/topic/400702-project-nexus/#findComment-5401896
LOOOOL
Is that the non modular one with two 8 pin pcie on one cable? I think my brother has one. Good enough for an HD7950 and an i3 though. Not bothering about warranties, I recapped it before even putting it in the PC with high end caps and added some noise filtering to the input and output as well as modded the fan to run faster as the amd card overpowers the noise from the psu anyway.
https://linustechtips.com/topic/400702-project-nexus/#findComment-5401898
Well, if ypu have anything else (such as another power supply or gpu ect) I would love to take a look at it. If I got a PSU that killed something, I would autopsy it and then give it the photonicinduction treatment. I have a 10,000v transformer stack waiting to make something asplode.
https://linustechtips.com/topic/400702-project-nexus/#findComment-5401905
"Rawr XD"
https://linustechtips.com/topic/400702-project-nexus/#findComment-5401923
Thats the one. I think it was on sale for like 25 bucks or something when he got it. He went to that from a complete bodge unit that originally was rated at 250w. Not sure how it handled an hd7950 and i3... I soldered pcie cables to it's main PCB
https://linustechtips.com/topic/400702-project-nexus/#findComment-5401934
I did not license or endorse this build.
You will be hearing from my lawyer sir.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/400702-project-nexus/#findComment-5402436
You also did not spell Nexus right
You will be hearing from my Language arts teacher
Its spelt the way it is for reasons
System Specs
https://linustechtips.com/topic/400702-project-nexus/#findComment-5402456
  • 3 weeks later...
the word nexus exists but not nexxus
Thank you for informing me of something I was well aware of.
System Specs
https://linustechtips.com/topic/400702-project-nexus/#findComment-5564409
