There is any Xeon processor better for gaming than 5960X?
Rlly tho a i5 4690k would only give u like 5 fps less tops unless ur doing tripple or quad sli
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371546
not really, I mean they are locked, and per thread performance is what you are looking for more than an insane number of threads
Shame too, because xeons are extremely well binned, would overclock like crazy
And the ones on LGA775 are proof of that (though my X5450 is sadly degraded).
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371557
if you want better gaming performance than a 5960x buy a 4790k
instead of more useless cores that games cant use you get faster cores that games will benefit from
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371564
some games that doesn't hold true. But I agree with the general sentiment.
Yeah a few games but unless ur rich i dont see how 1000$ more on a CPU is worth 5-10 fps, better to grab another GPU for that much money...
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371565
If gaming performance is what you're after, get some tight timing DDR3 with high frequency, like 2133 CL8, 2400 CL9 or something, and a 4790k.
Most games rely on only a few threads, and the 4790k with some decent ram and an overclock will have more single thread performance than the 5960x.
You can also OC the 4790k a lot higher, resulting in even more single thread performance.
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371571
I would agree more to push him to a quad core 8 thread i7 than an i5 like others suggested
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371572
I remember when I fell into the myth that Xeon was better than i7.
It is for specific things. If constant system uptime is critical, if you need many (>10) cores at low clock speeds, then they are much better than any i7.
For gaming, not so much. Unless you are running several different games all at the same time on a variety of VMs -- you might want a Xeon then.
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371575
He's trying to 3 way sli, He has to go 2011-v3 socket, No 4790k's or 4690k's
He didnt say it in this thread so how r we supposed to know
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371662
For gaming, 5960X is completely unnecessary for gaming, so... I guess the answer to your question is no.
Main PC: 4690k, LMG Edition G1 Gaming GTX 980, 16GB Hyper X Fury, Asus Z97-A, EVGA G2 850W, Crucial MX100 128GB, WD Red 1TB 2.5", Dark Rock 3
Laptop: Asus UX305 Monitor: Asus PB278Q Keyboard: Filco Majestouch 2 TKL Mouse: Corsair M65
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371673
You look at his posts, He had 15, its not that hard
Its not my job to read the OPs previous posts, i used the information i was given and gave my advice based on what was told. If i read everyones previous posts before answering a question id be here all year.
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371695
Yes, thank you for been so attentious!
I want to do surround 1444p@144hz gaming if that is possible
Then go for a 5960x and overclock. Its the best CPU for 3 way SLI.
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371720
also the 4790k's TDP is much lower, allowing for higher overclocks in addition to the already higher frequency :)
https://linustechtips.com/topic/398476-better-xeon-than-5960x/#findComment-5371763
