Nvidia recently showed "Project Logan" on SIGGRAPH event in California. This project is a High end mobile Graphics Processing Unit using 2-3 wolts and it is still able to power real-life-like graphics on "Ira" face app.
It will be able to support DirectX 11, OpenGL 4.4 and OpenGL ES 3.O.
Take a look for yourself and discover more about this in videos below!
What do you think? I think companies will probably replace modern GPU's on laptops and tablets with this one. Post below!
https://linustechtips.com/topic/39454-nvidia-project-logan/
is wolts some new unit for measuring resistance? :P
To the actual topic:
i think its a good step into the right direction but i cant imagine it being as fast as they say it is...
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/39454-nvidia-project-logan/#findComment-508811
Looks realistic to a creepy point lol
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
https://linustechtips.com/topic/39454-nvidia-project-logan/#findComment-508829
I think it is fast, if the thing was false advertise no one would even use it.
it may be fast but nvidia is comparing it to normal desktop solutions so that seems a little bit unrealistic to me.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/39454-nvidia-project-logan/#findComment-508849
if you can build things that fast with that small of a footprint, why not build large things that are even more powerful. I understand technology is getting small, but just think of all the power you can utilize today if you still make some big things. so no, i dont think mobile gaming will take over, in fact this is probably a step towards a better future for desktops:)
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/39454-nvidia-project-logan/#findComment-509043
you don't want to know what came to my head when i heard project LOGAN and from nvidia just made it lol
(1) high frame rate (2) ultra graphics settings (3) cheap...>> choose only two<<...
if it's never been done then i'm probably tryna do it. (((((((Bass so low it HERTZ)))))))
https://linustechtips.com/topic/39454-nvidia-project-logan/#findComment-509235
Awesome! But i dont want mobile gaming to take over. Ever
it won't ... because there will always be more demanding software that will require better hardware than mobile devices at that time
https://linustechtips.com/topic/39454-nvidia-project-logan/#findComment-509240
so maybe its time to wait for nvidias next desktop line
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/39454-nvidia-project-logan/#findComment-510176
  • 2 weeks later...
