Hi guys.
I've been keeping this huge card in the box of my Zotac Amp Extreme 2080 Super Box, the way you see on pics, and box on perfectly flat surface, under my bed.
But I got some paranoia that this huge cooler is pushing and bending the PCB, so maybe I should turn the card upside down in the box?
As you can see on pics, the card perfectly fits no pressing/touching on foam.
Why am I keeping it, don't ask please.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
7 minutes ago, leclod said:
If there's no pressure, I see no issue (even with some pressure there'd be no issue).
But there is pressure from huge cooler to the PCB in horizontal position.
weight of the cooler is split across the pcb
(and couldn't you just flip the box ?)
Edited by leclod
If you don't quote us, we won't know you answered
Do I need to?
It was in this position for months.
1 minute ago, frozensun said:
Do I need to?
Rofl, no.  The cooler isn't weight enough to bend a PCB, and they have cross supports between them.
It's a non issue, a plastic cooler and fans is lightweight anyway.
He mentioned turning it over to help with YOUR PARANOIA, not to help with the card.  The issue is 100% in your head.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Don't think at all this cooler is lightweight, this is a 4 slot card.
Comparatively to it being enough to bend a PCB while just laying there it is.
25 minutes ago, leclod said:
(that cooler is mostly a heatsink made out of metal)
Okay, metal and plastic combination 😉
OnePlus Ecosystem:
3D Printing:
Just to make it a bit more visual, see this:
The cooler is not just laying on the PCB, it is screwed to the backplate and the PCB is sandwiched between them. The pressure on the PCB is defined by the tightness of these screws rather than the physical orientation of the thing - it won't lift off from the PCB if you turn it upside down and it won't smash into PCB if you put it fans-up. The only place the pressure is exerted are the screw ports smooshed between the cooler and the backplate/retention plate and since those seem to be positioned throughout the PCB there won't be any stress points and the pressure would be evenly spread.
Long story short - you are perfectly fine.
B550 | R5 5600 | RX 9070 XT | Fedora KDE
