Pretty sure the answer to that is no.
https://linustechtips.com/topic/385037-5-way-crossfire/#findComment-5198183
no
https://linustechtips.com/topic/385037-5-way-crossfire/#findComment-5198188
Just curious can you run 4 r9 290x and an a10 r7 7850k apu together
No. But really, why?
The Rig: NZXT H440 M3 (Green and Black) (Ncase M1 coming soon!!) | Intel Core i5-4690k x BeQuiet PureRock Slim | EVGA GTX 1060 6GB SSC  | ASUS H81i Plus | 12GB EVGA SSC @ 1600MHz | Seagate Barracuda 2TB | Sandisk Ultra II 480GB | Corsair SF 450| LG 29" Ultrawide | CoolerMaster Quickfire Rapid TKL | Corsair M65 Black Sennheiser HD 558 (MOD) | Audio-Technica ATR 2500
https://linustechtips.com/topic/385037-5-way-crossfire/#findComment-5198193
Nope... And a 7850k will/can bottleneck R9 280s... Only one 290X would be used and it would be at like 20% load at most due to the terrible apu.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/385037-5-way-crossfire/#findComment-5198197
I think you need something like a 5820k and two 1500W PSUs. Honestly your electric bill would sky rocket.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/385037-5-way-crossfire/#findComment-5198227
windows doesnt support crossfire or sli above 4 way also the apu gpu is much different than a 290x and you cant crossfire different gpus also the cpu on the apu is terrible so it wont use all the power of the gpus because the cpu has to assign the gpu tasks and the cpu isnt fast enough to assign tasks quickly enough to hit 100% usage
https://linustechtips.com/topic/385037-5-way-crossfire/#findComment-5198251
Not to mention a burned down house.
CPU: Intel Core i7 7820X Cooling: Corsair Hydro Series H110i GTX Mobo: MSI X299 Gaming Pro Carbon AC RAM: Corsair Vengeance LPX DDR4 (3000MHz/16GB 2x8) SSD: 2x Samsung 850 Evo (250/250GB) + Samsung 850 Pro (512GB) GPU: NVidia GeForce GTX 1080 Ti FE (W/ EVGA Hybrid Kit) Case: Corsair Graphite Series 760T (Black) PSU: SeaSonic Platinum Series (860W) Monitor: Acer Predator XB241YU (165Hz / G-Sync) Fan Controller: NZXT Sentry Mix 2 Case Fans: Intake - 2x Noctua NF-A14 iPPC-3000 PWM / Radiator - 2x Noctua NF-A14 iPPC-3000 PWM / Rear Exhaust - 1x Noctua NF-F12 iPPC-3000 PWM
https://linustechtips.com/topic/385037-5-way-crossfire/#findComment-5198256
An A10 APU would get maybe 2fps on triple 4k, regardless of the GPU configuration. NCIX did a video on surround 4k, and, apparently, it is just too much for current hardware.
While I agree that the apu is a terrible choice for any 4k setup, considering the price the monitors and gpus needed, 4k is gpu bound, the cpu doesn't care what resolution is used. If the apu bottlenecks at 40 fps in 1080p, it will bottleneck at 40 fps at 4k assuming the gpu is capable of going higher
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/385037-5-way-crossfire/#findComment-5202582
