Microdia 512GB microSD card
ahhming
yes some phone do support it  , like the lg g4 which can support up to 2TB
The Xtra Elite, touts SD 4.0 and UHS compliance, with data transfer rates of up to 300 Mb/s.
Microdia hints it will be around the $1,000 mark
will be useful with android M as u can use it as external storage
Source:
http://www.cnet.com/news/microdia-will-sell-a-1000-ish-512gb-microsd-come-july/#ftag=CAD590a51e
think of all the porn you can fit on your phone now
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
how the hell is this almost 1 G? i have a 128GB card and it's like only 20 bucks,
Wonder if it's as reliable as other SD cards. They're so terrible...
After 2 years Sandisk still can't make a 32GB card last more than 6 months in somethins as simple as an eReader. Then again the 512GB card isn't being made by them so it should be fine.
"We also blind small animals with cosmetics.
We do not sell cosmetics. We just blind animals."
"Please don't mistake us for Equifax. Those fuckers are evil"
This PSA brought to you by Equifacks.
PMSL
"yes some phone do support it , like the lg g4 which can support up to 2TB"
Porn, photos, more porn.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
Amazing how phone manufacturers still wanna make me believe an additional 32gb of memory is worth 100 to 200 extra bucks when we can theoretically fit a tera no problem.
Current Rig
What about SSD..... :ph34r:
PMSL
Actually that's a rather interesting point: we've been making flash memory ever so more efficient and smaller but if we make it just a hair more reliable we can replace mechanical drives with it: you have your high speed SSD drives and your slower speed, storage flash drives 3 or 4 tb in the space of an m.2 stick.
Current Rig
Wut? the chinese ones?
Flash storage may be slower than an SSD, but it still beats a HDD in speed.
PMSL
Link to where you got this way too good to be true deal?
That highly depends on which eMMC/microSD and HDD you are talking about.
If you're talking high end eMMC and microSD then yeah, they can be pretty similar to an HDD and better in some areas (like small random read/writes) but they are awful in terms of sequential writes.
For example the HTC M8's storage is better than my HDD in most areas (especially random 4KB reads) but my HDD is like 6 times as fast as sequential writes (~20MBps vs ~120MBps).
eMMC is a lot faster than microSD as well, so chances are your HDD probably outperforms your microSD card by a lot.
Have you tried actually putting 128GB of things on it? A lot of times these cheap cards and memory sticks are just low capacity models with modified partition tables to trick your OS into thinking they are bigger than they really are. If you got for example an 8GB card that's sold as 128GB, then when you go above 8GB of data your files will become corrupt, so you should check it out before putting anything important on it.
Why is pricing so high for flash storage??
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Zowie S1-C | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
why are ssds expensive, same reason.
Desktop -  i5 4670k, GTX 770, Maximums VI Hero, 2X Kingston Hyper X 3k in raid zero.
Laptop - Lenovo X230 Intel 535 480GB, 16GB Gskill memory, Classic Keyboard Mod, Triple USB 3.0 Express Card.
http://www.ebay.com/itm/New-128GB-EVO-Micro-SD-Micro-SDHC-48MB-s-UHS-I-Class10-Memory-Card-/261910649530?pt=LH_DefaultDomain_0&hash=item3cfb175aba
Closer to 30 bucks, but it's still in that range.
Guess I can now use my phone as a phone and a portable HDD.
System Specs:
CPU: Ryzen 7 5800X
GPU: Radeon RX 7900 XT
RAM: 32GB 3600MHz
HDD: 1TB Sabrent NVMe -  WD 1TB Black - WD 2TB Green -  WD 4TB Blue
MB: Gigabyte  B550 Gaming X- RGB Disabled
PSU: Corsair RM850x 80 Plus Gold
Case: BeQuiet! Silent Base 801 Black
Cooler: Noctua NH-DH15
512GB of data, more than twice sandisk's 200GB shown like 6 months ago, in something the size of the nail on your little finger? This isnt going to spontaneously collapse into a black hole is it?
You know what's easier than buying and building a brand new PC? Petty larceny!
If you're worried about getting caught, here's a trick: Only steal one part at a time. Plenty of people will call the cops because somebody stole their computer -- nobody calls the cops because they're "pretty sure the dirty-bathrobe guy from next door jacked my heat sink."
That much storage in a tiny space is expensive.
Its also why high quality flash is expensive. CF cards laugh at all the people saying "OMG this is expensive". Please, Paying 500 for a card was a norm for people who absolutely needed the most reliable flash memory for their gear. At least CF is cheap enough now but we're not getting close to the $ per GB that platter drives are at.
Hopefully soon. I like using 128GB CF cards for another layer of archiving my photos, apart from the NAS backups and REDs that get thrown in a safe.
$30 for something that is normally $80?
Ebay Link... I dunno if its common with SD cards but I'm always skeptical with flash storage from Ebay. Too many people selling "128GB flash drives!" that are actually 8GB ones with the firmware hacked.
