Hey anyone know why my computers just randomly restarts without a warning, please help me, here are my computer's specs:
APU: AMD A10 7850K (Bought it for $152)
GPU: R7 260X (I know it cant dualgraphics but I had one that can before it)
Mobo: GA FM2A88XUP4 (was for $99 at the time)
RAM: AMD R9 RAM (was for $150 at the time, the day after it shipped the prices went up)
PSU: Cooler Master V750 (way too much watts, i was dumb when i picked my pc parts, my computers tdp is from 200 to 300 watts)
I have attempted to overclock the APU but decided not to because it was going to void my warranty, I was scared for the PC, this is the first out of 4 rigs I've built.
https://linustechtips.com/topic/379638-why-does-my-computer-keep-on-restarting/
I take it this isn't a new build. Check for a bad HDD, or overheating
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
have you checked your temps?
Also, take a look in the log of the pc.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
http://linustechtips.com/main/topic/379630-the-virus-challenge/
Try to make a guess. Just a wild one :P
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
I literally laughed out loud.
OP, try a diffrent power supply. that tends to be it if theres no error. if it was a hardware error that didnt result in a instant power loss, it would throw a code of some kind
you probably dont have proper cooling for cpu, have shorted some stuff on the mother board, have a virus, a foulty powersuply or some other random reson
Builds:
  • 1 month later...
My temps are fine, around 50 degrees, I've tried replacing the power supply, didn't work, I replaced all my hdds and ssds, I've even replaced the optical drive and then put it back just in case.
My two cents,in my build I forgot to put MB standoffs I put it on and it stopped the problem
