Xbox 360 wireless on PC?
Go to solution Solved by Nexxus,
You need a dongle, but the official ones are quite pricey and I have an unofficial one linus showcased on an old handy tech episode but it was finicky as hell to get the comp to recognize it and it threw up USB errors constantly.
id save the money and save up over the next few months and get an XBO controller with a dongle..or an XBO con now and get the dongle later (you can use it wired today via micro usb) frankly the xbo con is way nicer imho.
Can you use wireless Xbox 360 controllers on PC (games), or do you really need a wired  360 controller?
If so, do you need any adapters or something for it?
Might pick up a used 360 controller on a flea market later, but want to be informed first.
https://linustechtips.com/topic/372970-xbox-360-wireless-on-pc/
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/372970-xbox-360-wireless-on-pc/#findComment-5046671
id also be apprehensive about getting a used xb360 controler they are easily the worse cons i've had for dependability. The bumpers fuck up easy and will struggle to activate unless you press them in a very particular place (I think on the edges closest to the center of the controler) and are a bitch to repair and even then the analog sticks tend to lose tenstion and get very loose after years of use.
System Specs
https://linustechtips.com/topic/372970-xbox-360-wireless-on-pc/#findComment-5046697
yes
you need the adapter tho
costs more
There's a wireless adapter for them, but the software and drivers are complete crap to be honest. Wired is really a much better option.
Hmm, alright.
Thanks for the quick responses :)
If I see a cheap wired controller, I will pick it up. Don't care about wireless anyways.
https://linustechtips.com/topic/372970-xbox-360-wireless-on-pc/#findComment-5046794
I use a €15 wireless dongle. It is really easy to set up especially in windows 8.1. If you want to know how to set it up just pm me (in Dutch) and I'll explain.
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/372970-xbox-360-wireless-on-pc/#findComment-5046822
15 euros.. Well a new wired controller is 35 euros and if I could get a 2nd hand for 5 euros or so.. It might be worth it.
Will keep in mind, thanks :D
https://linustechtips.com/topic/372970-xbox-360-wireless-on-pc/#findComment-5046876
I'd love to use my old Microsoft racing wheel/pedals setup from my Xbox360. I picked up a wired xbox 360/windows controller for Fps/sideside scrollers. Could someone point me in the direction of a reliable wireless dongle/receiver?
@VortexS
https://linustechtips.com/topic/372970-xbox-360-wireless-on-pc/#findComment-5050460
you might wanna look into using that on PC I dunno if its compatable like might be missing FFB and what not.
System Specs
https://linustechtips.com/topic/372970-xbox-360-wireless-on-pc/#findComment-5050465
The official 360 wireless racing wheel works with the standard wireless adapter, which you could buy on Amazon: http://www.amazon.com/Xbox-Wireless-Gaming-Receiver-Windows/dp/B000HZFCT2
If you decide to buy this and the CD driver doesn't work (for me it didn't) shoot me a PM and I'll give you the way I got it to work.
https://linustechtips.com/topic/372970-xbox-360-wireless-on-pc/#findComment-5050558
