Hi,
So, I just discovered that end of last year EVGA had a promotion that you could get a free backplate for your 970, which I of course overlooked completely.
So I'm looking into getting some for my 970's, but I was wodering.
Do these backplates help cooling at all? Seeing that there are some thermal pads on the RAM modules on that side op the GPU.
Does anyone have "solid" proof of the efficiency?
Proof of badassness I do not need. I'm already convinced of that :)
Thanks guys.
James
https://linustechtips.com/topic/369819-does-970-backplate-help-cooling/
they are mostly for looks
metal backplates might reduce the temps of the PCB by a few degrees when using thermal pads, but its not a significant difference
Reduces GPU Sag.
Thank Jesus they put one on the GTX 780 Lightning, teh fat bitch weights around 1.5kg lol
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
If it makes contact with back mounted memory, and uses thermal pads, then yes, they can do quite a bit sometimes.
In most cases though, it might only reduce the pcb temp by a few degrees, since it doesn't have a thermal compound and doesn't make full contact in many cases.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
They are there for the select few who have cards with ram on the back of the card. Or help support inferior cards stay straight.
