Need a quiet PS for GTX 980 and I 7
macmus
- Seasonic Snow Silent 1050 watts
it's white and I have a black case :(
what about AX1200i .. is this one silent ?
AX is overkill and overpriced. Like I said above, there's no reason to go for the Seasonic Snow Silent when the Seasonic X-Series is the same, cheaper, and black.
If you're running a single 980, get the XFX XTR or EVGA GS.
"Rawr XD"
what about if i want to keep it silent even with SLI ?
One is a page for the series and the other is for the 1050w and 1250w models.
that's not true.. it look's like complete diffrent models to me..
Where?
The pictures are of the same unit and the model numbers are the same.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
I'm right now between:
Corsair HX1000i serries
and
Seasonic SS-1250MX
which one would be better ?
and
Seasonic SS-1250MX
The X 1250 is better but both are overkill.
what makes it so better ?
I am interested in Corsair Link in hx1000i  and people say it runs also very quiet..
Better built unit. CWT's highest end platform can't touch Seasonic's second-highest. Corsair Link is a gimmick honestly if anything. Who cares what voltages you're running at or how much power you're drawing from it, especially when it's a high quality PSU. You'll look at it once or twice then never use it again.
"Rawr XD"
Where?
According to JohnGuru
"Hello, folks, and welcome to my review of the brand new Seasonic X-1050, XM2 version."
XM2 is update revision...
When I look at amazon I have no clue which one is X-1050 and which oen is XM2.
ok i decided to go with:
http://www.amazon.com/gp/product/B00Q6CAZ4M/ref=od_aui_detailpages00?ie=UTF8&psc=1
in recent days besides of coil whine i started to hear also clinking sound when idle. I need to replace this PSU fast :)
Seasonic 1050W ATX12V/EPS12V 80 PLUS Platinum Certified Full Modular Active PFC SNOW SILENT-1050
should be good choice what you think ?
what about seasonic 520 fanless ?
will 520 be enough for this system ?
i have a new plan now to place 520 if it's enough and RMA with corsair this 800 and maybe use a new unitl later on when i will decide to go sli.
Okay, first of all, 1300w is COMPLETE OVERKILL. You don't need that much power unless you have like, quad 290s. EVGAs 850G2 or 750G2 is plenty and would actually be a great choice.
I'm not SAV1OUR. I promise. | Number of successfully bricked phones: 1 Samsung Galaxy S5 | 01001001 01110100 00100000 01110111 01100001 01110011 00100000 01100001 01101100 01101100 00100000 01100001 01101110 00100000 01100101 01101100 01100001 01100010 01101111 01110010 01100001 01110100 01100101 00100000 01110010 01110101 01110011 01100101 00101110
what about 520 fanless ?
I'm little concerned about my case which is NZXT H440 .. it may have no enough ventilation
