Posted May 2, 2015 Hey guys! So as it stands I need a new case. I can't fit in my current one. As I couldn't fine anything that I like and is in my pricerange I was thinking of building a case. I already found most of the stuff I need. Altough I'm not sure yet how to do the motherboard standoffs. Is there any way to do it home without any specialized tool? I added a few screenshots of the early designs. Any suggestion would be appriciated!Thanks a lot! Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU Alcatel OneTouch D5... IT WORKS!! http://pcpartpicker.com/p/BxMjTW Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2015 For standoffs on my wood case (check my NAS link in my sig) I just used some plastic spacers from a local hardware store. Basically polyurethane 1/4 inch spacers, worked great! Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s iPhone 14 Pro - 2018 MacBook Air Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2015 Looks like a Corsair Air 540 on it's side to me... :lol: I think you can buy motherboard standoffs separately. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2015 You can use normal screws and a stack of (plastic) washers. Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2015 Author Looks like a Corsair Air 540 on it's side to me... :lol: I think you can buy motherboard standoffs separately. It is kinda similar, but this is like 1/4 the price So there is that. Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU Alcatel OneTouch D5... IT WORKS!! http://pcpartpicker.com/p/BxMjTW Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 2, 2015 Author You can use normal screws and a stack of (plastic) washers. For standoffs on my wood case (check my NAS link in my sig) I just used some plastic spacers from a local hardware store. Basically polyurethane 1/4 inch spacers, worked great! That is an excellent idea!! Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU Alcatel OneTouch D5... IT WORKS!! http://pcpartpicker.com/p/BxMjTW Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 3, 2015 Author UPADTE: So I got a few models and made a semi final version of the case! Intel core I5 4460, Gigabyte H97M-HD3, Gigabyte gtx 760, 8 GB corsair value ram, Thermaltake core v21, Thermaltake Smart 630W PSU Alcatel OneTouch D5... IT WORKS!! http://pcpartpicker.com/p/BxMjTW Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 3, 2015 it looks good. Maybe you should give the HDDs a bit more room to mount them on antvibration pads when they are so close together. But go on Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
