I want something that will give me better audio I am currently using a rampage extreme V so the audio is already decent and I am using M50x's if that matter. So i was thinking about a sound card but in Logan's video here he says they don't really make a difference compared to on board audio. is this true?
CPU: Intel Core i7-5820K @ 4.1GHZ | MOBO: Asus Rampage Extreme V Eatx LGA2011-3 | RAM: 16.00GB DDR4 G-Skills Ripjaws @2400Mhz | GPU: 2x Gtx 980 | CASE: Cooler Master Cosmos 2 | STORAGE: 400GB INTEL 750 Series PCI-E SSD/ 3TB Western Digital WDC | PSU: Corsair AXi 1200w | DISPLAYS: ASUS PB287Q (3840x2160@60Hz) And LG27MU67 (3840x2160@60Hz)
https://linustechtips.com/topic/358157-do-sound-cards-do-anything/
No, the 5 extreme has amazing sound, so there isn't a reason for a sound card. I wouldn't even get an external amp/dac until you get quite a bit above the m-50 level.
Yes. Those "gaming" soundcards basically don't do anything when compared to onboard audio. HOWEVER, if you spend your money on a real DAC, the differences are huge. I really don't recommend getting sound cards like Logan showed, unless you simply need more outputs than your motherboard currently has.
If you're looking for better sound and not more ports, then look into something like the FiiO E10K (guilty, I love it) or an ODAC, and check out Head-Fi.org
|  Athlon 750K   |   EVGA GTX 750 Ti FTW  |  Acer Aspire E15 - i5 6200u, 940M  |
|  Sennheiser HD 518   |   FiiO E10K DAC and Amp  |
Moto G (1st Gen)
They produce sound
Incorrect, the speakers are what produce the sound :P
the sound card just converts it from digital to analog.
alright. thanks everyone!
