Please help find a affordable power supply for a friend!
Solved by Aniallation,
He is looking for a upgrade for his pc, and wanted to get a better gpu. Any suggestions? He is low on cash but will save up for it if need be. No specific budget but as low as you can please
What do you reccomend for a PSU / GPU? I was thinking maybe a 500 watt and a 270x. User Dotoren on the forums here agreed that it would be a good choice. Anyone have any good power supplies that they can find that are cheap and reliable? He can't afford a system blowout.
The best bang for your buck if you want a good solution will be a good mid-range PSU like the XFX ProSeries 550W, and an R9 270.
Video Card: HIS Radeon R9 270 2GB IceQ X² Video Card ($126.98 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($44.99 @ NCIX US)
Total: $171.97
Generated by PCPartPicker 2015-04-22 10:03 EDT-0400
I'm using a similar setup right now and I'm happy with it. Solid 60FPS in GTA 5 at 1080p high, can't complain at all. However for AAA gaming, your friend might want to consider upgrading CPU in the future.
