Help me pick a mobo?
Solved by ForsakenLive,
@ @ForsakenLive @Stijncat @bob345 @Dabasepc
I apologize for the confusion, Amazon has faulty information on their page for this CPU (see below)
I was recommended this by someone else here on a different post. Is this still a good mobo, or should I go with a z97 or whatever you guys are saying?
Thanks for all the quick help though.
That's confusing ![]()
However it looks like it's an i5 4440, so it should be 1150.
The motherboard you got recommended works fine, but lacks the USB 3.0 Headers for the front panel on the case.
