Waterblock from EKWB or the titan X cooler
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/349284-sexiest-gpu-cooling/#findComment-4753052
*insert unpopular opinion puffin*
my favorite is the sapphire vapor-x 290x
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/349284-sexiest-gpu-cooling/#findComment-4753072
XSPC Razor. SO. SEXY.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/349284-sexiest-gpu-cooling/#findComment-4753078
EKWB FC with matching EKWB Backplate. For air coolers, XFX DD and EVGA ACX 2.0
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/349284-sexiest-gpu-cooling/#findComment-4753108
MSI Twin Frozr > Windforce > Vapor-X
https://linustechtips.com/topic/349284-sexiest-gpu-cooling/#findComment-4753111
Aesthetics or Performance? If the latter, you should get checked out. :P
https://linustechtips.com/topic/349284-sexiest-gpu-cooling/#findComment-4753126
Sexiest gpu cooling
Not sure about performance, I just like how these look.
https://linustechtips.com/topic/349284-sexiest-gpu-cooling/#findComment-4753157
MSI Lightning, like on the 290X And 780Ti.
Really hate the Nvida reference design, but I'll have to settle for it when I pick up a Titan X in the coming months.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
https://linustechtips.com/topic/349284-sexiest-gpu-cooling/#findComment-4753462
