Opinion on these fans
Pony080905
I know corsair isn't a bad brand, I just bought a 2 pack of these fans for my case, I know I shouldn't have gotten the static pressure ones but I wasn't paying attention, what are your opinions on these fans, run on sentence for the win
http://www.corsair.com/en/air-series-sp120-led-white-high-static-pressure-120mm-fan
The weird kid in the corner eating glue
“People think that I must be a very strange person. This is not correct. I have the heart of a small boy. It is in a glass jar on my desk.” - Stephen King
gr8 m8 i r8 8/8
My friend uses one of those, they're good on Heatsinks and Radiators, not sure for case fans. Im stuck with Chinese Dazumba
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
gr8 m8 i r8 8/8
That brand sounds like a dance
screw it too tight, too loose, the bearings will dance
(NOW)War Horse:
(WAS)Old Coop:
They're not bad. A bit loud and move not a lot of air, but they're definitly worse fans.
I would rather recommend be Quiets Silent Wings 2 or some Noctua fans.
I Went and looked at the specs of my current fan, and the specs of the ones I bought, they are slightly louder but move more air
they are good for case intake if you have hard drive trays directly in front of the fans
That's what one of them is going to be used for, I have two hard drives in raid 0
In a pure decibel to CFM ratio the Corsair static pressure fans trump the airflow models @ 30db.
1. Overclock until the magic smoke comes out. 2. Modify until broken. 3. Fix and repeat.
4670k - 16GB - 290X - 1440p Freesync
