MS Office language pack causes severe system crashes? Help please!
Did you use a registry cleaner at any point in time, or did you get a virus/malware at some point with the same Windows install? That might explain the problem, despite having everything working fine after.
Your system was definitely before all of this. What you have done simply pop-ed it up in front of you.
Here is something you can try (complete clean of Office, all settings and configurations will be lost):
-> Uninstall Office with this https://support.microsoft.com/en-us/kb/971179/
-> Once done, restart your system, and check Program & Features, and make sure everything from Office is gone.
-> Go on the install location of Office, ad make sure everything is gone.
-> Empty your Temp directory (C:\Users\<Account Name>\AppData\Local\Temp -- note: AppData is a hidden holder)
-> Go to the registry with regedit, and go to: HKEY_CURRENT_USERS\Software\Microsoft, and delete the folder (key): Office, and Office Labs (if you don't see it, good. It means the uninstaller took care of it)
-> Now go to, again in the registry: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft, and delete the folder (key) called: Office (if you don't see it, good. It means the uninstaller took care of it)
-> Now, you can close Regedit, and now navigate to: C:\Users\<ACCOUNT NAME>\AppData\Local\Microsoft, and delete the folder Office, and Office Labs
-> Go to: C:\Users\<ACCOUNT NAME>\AppData\Roaming\Microsoft, and delete the folder Office.
Now restart your system, and install Office back.
