SpeedFan - When I Change Speed my CPU goes up to 80c at idle
Solved by NeverNotExhausted,
it connected to the CPU fan header
Is that fan header reporting a rpm? Or have you tried to hook it up to a molex/fan splitter?
I'm just hunching it but I reckon it's the pump
