Best £100 Sound Card?
Subduck
What's the best internal sound card?
ALCATRAZ |   CPU: i9 9900k @ 5GHz, Motherboard: Asus Prime Z390-A, RAM: Corsair Vengence LPX 32GB, GPU: Gigabyte 1070Ti Case: Zalman MS800 Plus, Storage: Corsair 2TB NVME | Crucial M550 128GB SSD  |  WD 640GB HDD, PSU: XFX Pro Series 1050w, Display: ASUS MG279Q, Cooling: Noctua NH-D15
What is your reasoning behind getting a sound card? they're not always the best option
If I were a bird, I'd fly into a ceiling fan.
Motherboard? Headphones? Speakers? Place of purchase?
Place of purchase: United Kingdom.
Motherboard: Sabertooth 990fx R2.0.
No speakers.
TurtleBeach Headset.
What is a better option then?
An amp and dac would be better, something like an Objective 2 by epiphany acoustics (look on overclockers, they've got them there) or a fiio E10K for example.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
No speakers.
Usually motherboard audio is good enough and what Turtle Beach headphones? Because many of them are USB
That headset has a USB connection does it not?
It is not to plug a headset into. It is to plug a 6.3mm jack into from things such as guitars.
No speakers.
It's Turtle Beach... you won't notice a difference by spending $100 on a sound card
"Rawr XD"
the usb amp on my turtle beach x12 just hisses.... my $7 monoprice 9396 are better... I Personally still get a slight hiss, but that's my 6 year old motherboard (I can hear it load stuff...), so I would say upgrade your headphones then get a sound card or amp/dac.
You mean so that you can record audio from it? Anything else that you'll be using it for?
a headphone amp would be better if you just want it to be louder, it's going to be cheaper and you can take it around with you for your phone etc.
If you move beyond a headset to headphones then I'd suggest and amp & DAC combo, as others have suggested but this would be somewhat expensive.
Edit:
I just saw it's not for headphones/headsets but instruments so take a look at this link http://amazon.co.uk/Alesis-Guitar-Link-Audio-GuitarLink/dp/B002IDTPB2
It's only £17 and I've known people to use it without complaint
