I was just wondering what the best phone camera was that is available on the EE network?
List of available phones on the EE network: http://shop.ee.co.uk/mobile-phones/pay-monthly/gallery
iPhone 6 camera is amazing tbh
https://linustechtips.com/topic/325733-best-phone-camera/#findComment-4424154
I believe the 6 has a good camera and Note 4 too
https://linustechtips.com/topic/325733-best-phone-camera/#findComment-4424158
It's going to be a race between the HTC M9 and iPhone 6 Plus, you really won't notice the difference unless compared side-by-side though. However I'd wait for the S6 to be available to the masses and we can see how good the camera is on those, apparently it's much improved.
"Rawr XD"
https://linustechtips.com/topic/325733-best-phone-camera/#findComment-4424164
I reckon the iPhone 6/6 Plus. It's definitely a step up from my iPhone 4S, not by the overall but the camera too :D
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/325733-best-phone-camera/#findComment-4431590
Can't go wrong with the Xperia Z3 either. Phenomenal low light performance, but do bear in mind the 20.7 MP size is with photos in the 4:3 aspect ratio. Video quality is decent, though recording in 4K on any sensor will cause the device to heat up.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
https://linustechtips.com/topic/325733-best-phone-camera/#findComment-4454554
I am a OnePlus One user, but I have to say: iPhone 6 Plus
2nd place: Lumia 1020
My PC: Intel Core i3-3220 | Alpenföhn Civetta | XFX HD 7770 1GB | ASRock B75-Pro3-M | Kingston HyperX Blu 8GB | beQuiet PurePower L8 430W | Seagate Barracuda 7200.14 1TB | Kingston V200+ 60GB | NZXT Vulcan | Soundblaster Play Replaced by Notebook + eGPU
My Notebook:   Apple MacBook Pro Retina 13-inch, Late 2013; Core i5 4258U @2.4-2.9 Ghz, 8GB RAM, 256GB PCIe SSD, Iris Graphics 5100 + GTX 960 eGPU
My Phone: OnePlus One with CM12      Camera: Nikon D3200 + 50mm f/1.8G + Kit lenses
https://linustechtips.com/topic/325733-best-phone-camera/#findComment-4463493
