Micron Configure is Core i3 3220 h61 8gb ram. So I want to buy Tt 450w. Is this pus can handle it or what/which..?
ThermalTake doesn't make great PSUs in the low end. Are there any other brands of PSU that you can get, such as Antec or Seasonic?
"Rawr XD"
I don't recommend a low end Tt, but I do recommend either an Antec, EVGA, Cooler Master, XFX, or Seasonic power supply. And you will only need 400-500 watts for your config.
FairladyZ | If you want to reply to me, please quote my post! Idiocity, the best money wasting PC build ever!
It's not as simple as just the brand. You need to look at each individual unit themselves at that particular price point. Which specific Thermaltake model are you looking at? Which Corsair model? Which Cooler Master model? etc?
Where are you buying from (links)? What's your budget?
You don't have a graphic card in that build?
bro,
Corsair VS450  http://pcworldrajshahi.com/36/PC-Hardware/PSU/Corsair-VS450
Thermaltake 450W Lite Power Black
and my Gpu  R9 280
i donno how many time i posted the same topic but still now i cant get my ans . so guys please tell me which  power supply do i need .
my configure i3 3220 8gb ram and r9 280
and what psu i need
pick any of them
http://www.ryanscomputers.com/Power-Supply-Unit/All-Brands/10
450-500W+ should be fine.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
a bronze 80+ 500w+ psu should do the trick.
CPU I7 - 4720HQ RAM 2 x 8GB • GPU Nvidia GTX 850M Storage 250GB 850 EVO - 1TB Seagate Hybrid
Keyboard CM Storm QuickFire Rapid-I (MX brown) & Pok3r (MX clear) • Mouse Logitech G502 • Sound Audio-Technica ATH-M50X • OS Windows 10 Pro - Linux Arch
Storage Asustor AS7004T
  • 3 weeks later...
budget?
location?
EVGA 500 watt is 20 bucks
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
it need 2 plugs
are you in the middle east
I want to buy this gpu but which psu have 2 6pin cable.
Most, you could just get a Corsair 550w/Corsair 600w. Depending on your budget you would go with a different series of PSU
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
