Passive cooling mate
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4285797
Because mobiles are passively cooled and some TV's do have fans.
Phones don't get as hot too
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4285801
Because they clearly dont need them
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4285803
Mobile's and TV don't generate enough heat to need a fan. Besides, imagine how it would be to have a fan in your phone! It would vibrate all the time and it would be loud and thick as hell.
Even a desktop CPU or GPU can run without fans on lite loads. For mobile's, a heatsink (or not even that) is enough and most of the TV's dont even have those.
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4285843
Phones passively cool the main components by spreading the heat out usually across the back casing of the phone. One of the main benefits of metal cased phones over plastic cased phones is that they theoretically can keep the main components inside the phone cooler since the metal obviously conducts the heat away from the components a lot better. Unfortunately, this can lead to sweaty hand syndrome, but the phone internals theoretically might last longer.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4285848
Mine doesn't
I guess some do.
See spoiler.
Just a random inside of a TV found on Google.
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4285883
Some TV's do have fans. But most just have passive heatsinks instead.
As for phones, it would add a lot of bulk to the phone that isn't really needed. It would also likely be one of the first components to fail if used on a phone.
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4285918
Ancient tech, obviously.
A TV is still a TV.
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4286006
If your TV had a fan it would have to very quiet. No airflow noise or motor noise. Otherwise it would be very distracting when the quiet part of a show or movie is on.
Fan on a mobile would be way to cumbersome. And most fans under 40mm are a big waste of time. Since they have to go very fast to make any airflow. And then comes the noise of a small fan.
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4286015
Yea LOL that's what she said.
ಠ_ಠ
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4286568
Plasma TVs need fans because of the heat generated... But any non-plasma TV that needs fans is just poorly engineered.
Agree. Most older Plasmas had fans. Some of the later ones did not, as they were able to reduce heat output quite a bit (though they are still thicker to allow airflow inside the chassis). Those without fans work like the original iMac... they are convection-cooled.
https://linustechtips.com/topic/315342-cooling-fans/#findComment-4383964
