What GPU is right for me?
Go to solution Solved by Will Barnard,
Probably going with the 970
Hey guys,
First off, here's my setup:
               CPU Intel Core i7 4790k @ 4.00GHz
Motherboard MSI Z97 GAMING 7
              RAM 12GB (1x4GB+1x8GB) Corsair Vengeance 1600Mhz
              GPU EVGA NVIDIA GeForce GTX 660 2GB FTW SC
         Storage Seagate Barracuda 1TB
               PSU Corsair AX760
So I've recently upgraded my CPU, now I need a GPU that can keep up with it  ^_^
I don't really want to spend more than £300 (which is roughly $450), so I'm looking for a card that can run the latest AAA titles on the best settings possible for the money.
I'd rather an NVIDIA card, but feel free to suggest AMD if you think its the best I can get for £300. Also, it has to have 4GB of VRAM.
Please help me, there's so many...
Thanks in advance  :P
https://linustechtips.com/topic/302419-what-gpu-is-right-for-me/
Maybe a 280x
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/302419-what-gpu-is-right-for-me/#findComment-4109301
As much flak as it's gotten the 970 is still a solid 1080p card.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/302419-what-gpu-is-right-for-me/#findComment-4109341
This is very true ^^^
But in general its easier to find cheap 290s :)
Oh no doubt! But NVidia fans will enjoy going that route :)
https://linustechtips.com/topic/302419-what-gpu-is-right-for-me/#findComment-4109363
-snip-
I'd actually grab a 970 at that price! You get to save $100.
But then again, you can also dish out $450 to grab a 780ti for $450... OR sell that 660 for $100 and grab a full 980.
Main Rig: Illya V2, the Tiny Titan: ||i7 8700k 5GHz @ 1.385v (delidded)|| ||NVIDIA RTX 3090 FE|| ||KrakenZ63|| ||ASRock Z390-Phantom-ITX/ac|| ||Corsair SF750||
2nd Rig: Illya V1, the Air Cooled Prodigy: ||i7 4790k 4.4GHz @ 1.3v|| |NVIDIA RTX 2080 FE|| ||Be Quiet! Dark Rock 2|| ||ASRock Z87-E|| ||SeaSonic G-Series 550w (Carbon Fiber Mod)||
Captain isHypnophobic of the LTT Conglomerate.
https://linustechtips.com/topic/302419-what-gpu-is-right-for-me/#findComment-4109379
I highly recommend waiting until the 3xx from AMD is unveiled. If you absolutely can't wait I would recommend the R9 290/x as others have mentioned.
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
https://linustechtips.com/topic/302419-what-gpu-is-right-for-me/#findComment-4109385
https://uk.pcpartpicker.com/parts/video-card/#m=8,14,18,27,41&c=186,146&sort=a7
970 or 290X, either is well within your budget and will perform brilliantly.
Actually no, the 970s have a considerably lower starting price, and for one with a decent cooler they are pretty much the same. See above.
EDIT: oh you said 290, not 290X. Never mind.
https://linustechtips.com/topic/302419-what-gpu-is-right-for-me/#findComment-4109398
I will admit that the 970 is the finest 3.5 GB card on the market at least ;)
Since the last 500 mb are 5 or 6 times slower.
https://linustechtips.com/topic/302419-what-gpu-is-right-for-me/#findComment-4109411
I would wait a couple months for when amd's r9 300 series come out (they come out in quarter 2 of 2015). A bunch of people are recommending the r9 290 and gtx 970. The r9 290 and 290x run a little hot so personally I wouldn't get it, and the 970 is having VRAM problems when getting up to using 3.5 to 4.0 GB of VRAM.
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
https://linustechtips.com/topic/302419-what-gpu-is-right-for-me/#findComment-4109421
After research, definitely 290x
https://linustechtips.com/topic/302419-what-gpu-is-right-for-me/#findComment-4109435
