Normally i look it up before asking but i couldnt find a answer . I cleared cmos and reinstalled windows7 but when i went to install drivers from the mobo disk i got an error on restart. It say nero boot loader v6 my model is not support ten it ask me to restart but it just restart to the same screen. I didnt have any problems like that when i had my computer booted up the first time. Any ideas
https://linustechtips.com/topic/299496-my-build-help/page/13/#findComment-4321958
ok i figured it out. I had to change boot priority odd back to 2nd. Btw i had to clear cmos x3 and reinstall windows 7 x3 due to problems along the way. Im not damaging or corrupting anything am i?
I have done that many times, especially on my older system with all the overclocking.  Trust me, short of taking a hammer to your PC... you will not do damage.
https://linustechtips.com/topic/299496-my-build-help/page/13/#findComment-4322178
my hdd is disconnected since last night, my first build experience has been stressful. I would like to just thank you again for staying throughout this bumppy road. I afraid to install windows update now, that asrock screen mighy pop up again and freeze on me lol
https://linustechtips.com/topic/299496-my-build-help/page/13/#findComment-4322226
You will figure it out.  What you learn with this one will benefit you down the road... even if feels like crap.  :huh:
https://linustechtips.com/topic/299496-my-build-help/page/13/#findComment-4322598
Hey you are back.  I was worried something went horribly wrong.
Hey i would like to run a speed test for my ssd and hdd which software do you recommand?
What type of software do you want?
Also my ddr4 ram. Is gpu testing neccessary?
No.  Only test your RAM is you are BSOD'ing or getting random program crashes.  If it ain't broke... don't fix it.  That (GPU testing) can be done later, get your software in order.
one of the usb port in the front panel case has problem recognizing usb is plugged in. Device does get power on but not recongnized
USB 3.0 ports usually require driver updates, mine do anyway.  Go to AsRock and find the utility programs and drivers you want and need.  Read through the program list and search whatever you don't understand.
After you get all you software just right, we will work on cloning your drive.  Then you can test whatever you want to.
https://linustechtips.com/topic/299496-my-build-help/page/13/#findComment-4325496
everything is up and runing even had all windows updates without frozen asrock screen.
I just want to check if my ssd and hdd is running at the right speed. I have installed the usb3 driver, maybe ill do it again
the wierd thing is its only 1 of the usb2 port in front of the case. It worked for my exterbal hdd eariler and before i reinstalled my windows. Now every time when a usb device is plugged into that port it wont recongnize the device. Any ideas?
also i dont quite get why i need to clone my ssd or hdd.
https://linustechtips.com/topic/299496-my-build-help/page/13/#findComment-4325592
You don't need to, you want to... even if you don't know it yet.  Right after you install Windows and update it, your system is "cleanest".  Put all the basic programs that you know you will want on.
If ever come the day that you need to re-install, you don't have to go through all the setup, the updates, the program installations.  Everything is done already and stored as an image on your storage drive.
Front USB 3.0 - You can try this:  put the device in it and wiggle it.  If it is detects the device, then it is simply not seating the USB plug well.  Mine are a little wonky.  I have to touch it sometimes to activate it.
You installed Windows in 5 minutes, your SSD is writing(sequentially) at the right speed.
https://linustechtips.com/topic/299496-my-build-help/page/13/#findComment-4325623
