My First Pc Build
Solved by stconquest,
So if I just left the RAM alone and overclocked the CPU, the RAM will run at a slightly lower speed? (not a very noticeable one right?)
Also I remeber you said it before, but what software do you use to overclock the CPU and GPU, and how much does it cost to download (or do u even download it)?
After you buy the hardware, overclocking is free =).
