BEST HDD that make no sound?
Solved by Captain_WD,
Hey out there.
I will like to have great HDD for my Shadowplay and video editing.
I need only 1 drive with 1-2 TB space on it. And i like it to be really fast, but i hate the HDD sound when they are working.
I know WD black is fast but is also really loud and i dont like that.
I dont thing SSHD will help me that my file size is around 3-5GB and working with alot of files at the same time.
So do one of you know a great drive that is fast and is really silent when is working? Price 0$-150$.
Hey Mads-Ejnar,
What the guys pointed out is pretty good. The faster a drive is, the louder it tends to be. Your best bet is to get a SSD (if you can afford a suitable size that you need). SSHDs are also an option but since tehy also have a spinning platter, they tend to be pretty much as loud as a regular HDD.
So in terms of regular HDDs, I would look for a NAS/RAID class drive, an energy-saving drive or a recording-oriented drive. These three types of drives tend to make the least noise and still have good read/write speeds.
The guys here already mentioned WD Purple, WD Red and WD Green as well as WD Blue. Here are a couple of words on each:
WD Blue is an everyday drive that works good, not too loud and is rather fast.
WD Red is a NAS/RAID class drive that works pretty quiet and still has a good transfer speed.
WD Green is very good in terms of energy efficiency and quietness, but tends to b a bit slower, compared to the others.
WD Purple is a drive designed for surveillance and thus works really quiet, but it never spins down and has a rather slow random read/write speed (while the sequential read/write speed is great).
WD Black, as you know, is a performance drive which is fast but loud.
WD Red Pro is again a NAS/RAID class drive which also works quiet but spins at 7,200 rpm and has longer warranty, compared to the regular WD Red.
Out of all those drives, WD Green, WD Purple and WD Red are the quietest, having 21 dBA during idle (1TB version of the drives). During seeking times, WD Purple is the quietest of all with 22 dBA together with WD Red with also 22 dBA and WD Green is with 24 dBA.
If you need more info, you can check their spreadsheets on the website http://www.wdc.com/en/%C2'> simply ask me
Thanks @ShadowCaptain for the good words. We simply try to advise people and provide as much information as possible. It is only natural that we offer WD products as solutions since we work for Western Digital. It is up to the user if they would go with the product or chose a different one. We simply give an option.
Hope this helps,
Captain_WD.
