Solution for a heat in a hot room
Jaredcb03
I live in TX and it gets hot in this room (only 11x11 or so) and the wall in the pic is kind of west facing so I have heat issues for most of the year. Long gaming sessions with a GPU pumping out heat certainly don't help. I struggled with this for a couple of years before finding a solution.
Underneath the desk on the right I have all the necessary cables running through the wall to a spare/guest bedroom on the other side. I have the other cables hidden behind a bookshelf. This room is very rarely used so I can crank up the fans if needed and can't hear a thing in the room I'm in. This also help with heat quite a bit.
I have found one downside to this setup... I have to go into the other room to see my PC :( However I find not having a room hot as hell to be worth it.
What do you all think of my setup? Any other solutions for heat in a small room you can think of (short of installing another A/C unit)?
Intel i7-7770K | Asus Maximus X Hero  | EVGA GTX980 SuperClocked | 16GB Memory| Samsung 960 EVO M.2 | Corsair RM 750W | Dell 27" S2716DG main display | Dual Dell ST2320L 23" Secondary displays | Windows 10
Logitech G710+ Keyboard | Logitech G502 mouse | Kingston HyperX Cloud headset | Corsair H100i
Looks clean.
I see a window--open it (if it opens).
what I do is I keep my room SUPER cold at all times, so I love my pc heat. It's kinda backfiring now that I can't have my pc on for a few days .-.
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
Looks clean.
I do open the window when it's cool outside... Once again I live in TX and most of the year it's pretty hot outside...
Looks pretty cool.
We don't bother heating the entire house much. And then my PC's in a massive room so it could never heat it up.
Sig under construction.
Whole Room Watercooling part 5
Gaming Rig: i5-3570k+H100i (4.3 ghz) | P8Z77-i Deluxe | MSI Twin Frozr 7950 Boost | HX650 | 1TB HGST | 840 Evo 250 GB
Looks clean.
 Correct me if I'm wrong but wont that introduce humidity thus causing pc degradation due to moist.
doesnt matter no matter where you are there will be humidity. even so it doesnt effect pc's that much anyway.
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
thats a nice setup and with that setup you can have loud as fuck delta fans in your case
EDIT:I am interesting in how you transferred cables though can you take photos of it?
Yep, i'll take some when I get back in about 1.5 hours.
