First Post on this forum. My build log has been posted on a few other forums so i'll add the dates before each post.
2-12-2013
Rig specs are as follows:
Mountain-Mods UFO
Intel i7-870
AMD HD5970
16gb G-Skill DDR3 1600
EVGA p55 Micro
60 GB Mushkin Callisto
Mixed Magnetic Drives
Corsair AX750 PSU
Current Water Equipment:
Swiftech 655
2x Thermochill PA120.3 (25mm Spacing)
EK(before shitty manufacturing) HD5970 Block
Bitspower Summit EF CPU Block
Bitspower Matte black 1/2"ID Barbs
Still need to purchase:
Reservoir or pump top
Tubing
Bitspower G3/8-G1/4 Adapters
Current plans are to strip the case and plasti-dip it matte white.
STAY TUNED! :up:
Current Pictures:
Watercooling Equipment
8469495526_85d3cdbfd5_b.jpg8468401673_c18259e55c_b.jpg8468402691_438a008cc1_b.jpg8468404143_32d0603434_b.jpg
2-26-2013
Paint Now applied
8531720774_e273854c25_b.jpg8530611381_5bfef9efbd_b.jpg8531724022_733d02133a_b.jpg8530569223_b6a95cf314_b.jpg8531682264_da048ebbcc_b.jpg8530584477_8e79a93a85_b.jpg
Finished Product
3-05-2013
I definitely got my laugh in this morning when I saw the message on the bitspower bag
3-08-2013
Took the air cooler off of the 5970.
Put some nice new thermal pads on it.
And put the waterblock back on
Pulled that old Prolimatech Megahalem off the i7
Now its ready for a little bitspower lovin :up:
3-09-2013
6-13-2013
New equipment came in!
Monitor Setup Before
Setup After
6-14-2013
Package from Sidewinders arrived!
Some pictures of the block
Finally got new acrylic windows for case as well.
Its all starting to come together! Only thing i'm missing is a full set of MDPC-x Sleeving
6-18-2013
So the card is up and running in the system. I've had exams for school all this week so no time to put the waterblock on. During study times though i did get some benchmarking/overclocking in. I can get it steady at 1175 Core with 1.2V but anything above that and the driver crashes. Not bad considering it comes stock at 863.
Some shots in the case as it stands now.
Highest clock of the day.
Best Unigine Valley run extreme hd at 1080p
https://linustechtips.com/topic/27876-project-thassos-pic-heavy/
Whoa. That looks amazing :D
i5 4670k - MSI GTX 770 gaming - Fractal design define R4 (windowed) - MSI Z87-G45 gaming - be quiet! Dark Rock Pro 2 - Corsair vengeance 8 gb (lp) - WB black 1tb - 256GB SSD - Corsair TX 750M - Ducky Shine 3
https://linustechtips.com/topic/27876-project-thassos-pic-heavy/#findComment-354872
Looks nice, sweet build overall. Just a q, did you want it white from the beginning or did you just "damn think im going white no"? Hehe
i7 4790K@4.5GHz-1.15V, BeQuiet! SR2, Asrock z97e-itx/ac, Kingston  Fury 16GB@1866MHz, GTX 670 2GB, 3x ssdNOW300V 300ishGB, Bitfenix Prodigy, OCZ ZT 750W Twittwit@enRodjavel
https://linustechtips.com/topic/27876-project-thassos-pic-heavy/#findComment-355090
@Jtrain
build looks really awesome,but whats the black stuff on the cpu?
It was just some leftover thermal paste, dont worry though, it all got cleaned off!
No i just decided i wanted to make it white, and if i ever want to make it black again i can peel all that paint off. :-)
Thanks for all the posts guys!
https://linustechtips.com/topic/27876-project-thassos-pic-heavy/#findComment-356421
What camera are you using?
Canon t2i
Wait what? The description says you're using a 5970. I'm assuming you're not using that, but the pictures show both a 780 and a Titan. Which are you using?
Original plan was to use my old 5970, ran into some cash and splurged for a gtx780.
The heatkiller block that i wanted has "GTX Titan" printed all over it because they use the same layout.
Wasn't going to wait for someone to come out with a dedicated GTX780 block when they are essentially the same card just mine has less RAM and cuda cores.
https://linustechtips.com/topic/27876-project-thassos-pic-heavy/#findComment-358737
