Matte or gloss monitor for gaming?
Specialixst
Should i get matte monitor or gloss monitor for gaming? I really don't know what to chose. If so, what is the difference between matte and glossy?
Glossy - Shiney
Matte - not Shiney.
Matte is better because light does not reflect off the surface of the monitor
My Build
GPU: MSI GTX 1080 ARMOUR | CPU: i7 9700k | Ram: 16gb 3200mhz Motherboard: ASUS Maximus XI Gene | Storage: 2x 1TB NVME 1x 500GB NVME 1x 120GB NVME | Case: Corsair 570X
TBH it is personal preference, I like matte as I am right next to a window and I can't stand the reflections.
It depends on what YOU prefer
CPU: Intel Core i5 4460 | GPU: XFX r9 280x DD BLACK OC EDITION | RAM: 8gb Kingston HyperX Fury 1600Mhz | Mobo: Gigabyte h97n-WIFI | PSU: EVGA 600B | Case: Cooler Master Elite 120 | Cooler: Stock intel | SSD: Samsung 840 EVO 120gb | Storage: WD 150 gb
CPU: Intel Core i7 4710MQ | GPU: NVIDIA Geforce GTX 850M | RAM: 8gb Corsair 1600Mhz | Mobo: Metabox WA50SJ Motherboard | Case: Metabox WA50SJ case | Cooler: Stock | SSD: Sandisk 256gb
:wub:  :wub:  :wub:
Best purchase this year, bcuz forza
Matte gets rid of at least some of the glare off the monitor from lights behind you, but it can result in a grainy looking coating that is visible especially on evenly coloured surfaces. A mild matte finish is generally the way to go.
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
Oh a glossy surface, the colors look better and more vibrant, on the matte monitor, the colors look more dull and not as vibrant. This is probably because theirs a coating on top of it. Yes, this applies to IPS monitors are well, not just TN.
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
I have glossy and because the shine doesn't shine directly against it, it isn't a problem.
If you have sun directly on it: Matte. If not: Glossy could do, but matte is great because you don't get fingerprints all over it.
If you play games during the day, go matte. I have glossy and its impossible to play games like metro last light during the day.
