Is there a way to mount a Rode NT 1 to a wall?
Izaya Orihara
So I've been using a Rode NT 1 for my Let's Plays for while now and I've used a janky floor stand but it's annyoing to use like this. I want to mount it to the wall. Is that possible?
(Money is less of a concern)
You could attach an arm to the wall with a few screws?
Yes I could do that. A arm mount is pretty much exactly what I'm looking for.
A boom arm slots into that thing I linked
What boom arm would you recommend?
So this thing will work and I'll be able put it  out of my way when I'm not recording?
http://www.bhphotovideo.com/c/product/924235-REG/gator_cases_gfw_mic_0010_frameworks_single_section_boom.html
This one and thing you linked and I'm good?
I don't think that kind would work, I meant the typical spring arm, as they have a little nug that sits in the golden slot of the thing I linked, and rotate by swiveling inside.
post-2468-0-95482100-1414259105_thumb.jp
post-2468-0-72284000-1414259162_thumb.jp
How about this arm? http://www.bhphotovideo.com/c/product/287488-REG/O_C_White_14192_B_Deluxe_Extended_Two_Joint_Microphone.html Also could you recommend me another wall mount? I don't like the look of the one  you linked... :P
Yes, but that is kinda pricey.
Cheaper one (assuming you're using that site): http://www.bhphotovideo.com/c/product/929266-REG/auray_ba_2en_broadcast_arm_2_section_external.html
Comes in black and white.
I like the looks of the O.C White Deluxe one better xD I'll get that one and the and O.C wallmount in black. Do I need anything else?
A drill, some screws, and the appropriate anchors.
