FX-8320 w/ GTX970 2-way SLI. Will there be bottlenecks?
vern021
GTX970 came out and made me thinking of buying two GTX970 instead of 780Ti since they're at the same price. I'm wondering if my 8320 will bottleneck the GPUs even when the 8320 will be overclocked to 4.5-4.7GHz?
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
yes but not a lot but you would see fps drops
My PC
[ I5 4690k (no oc) - Gigabyte Z97 D3H - 8GB Ram - Sapphire R9 280X Vapor-X ]
No bottlenecking would occur at all, the FX-8320 OCed is basically the same as the 8350, and both are very good CPUs, I doubt you'd need to upgrade any time soon.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
yes
What's the real answer guys? Can you give some supporting reasons from a reliable source?
Yes, it will, bottlnecking badly. Get i7 instead.
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
Regardless of your GPU setup, if you play something which cannot utilize all the cores, or utilize however many it uses well enough then yes there will be a bottleneck.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
Yes, it will.
Let's say that I'll be using 3 24" monitors or a 21:9 1440p monitor, how significant is the performance decrease(in %)? Will it run at above 60fps at med-high or max settings?
You do not need an I7 at all to run 2-way SLI GTX 970
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
*I5
My PC
You don't even need an i7 for gaming
^this. can you give a comprehensive opinion?
http://cpuboss.com/cpu/AMD-FX-8320
Provides a comparison between a FX-8320, 3770K and 3570K
http://www.futuremark.com/hardware/cpu/AMD+FX-8320/review
Futuremark scores, just showing that the 8320 is keeping up with any other high end CPU.
WHAT!??!?!?!
How do you guys think that an 8320 can bottleneck GTX 970s?!
You would probably be able to play on a 21:9 1440p monitor at High settings but 60fps i am not too sure about that since the Benchmarks for the 8320 Don't look too
good.
BUT of course you will be able to play games like a boss with no problems @1440p
My PC
It will depend on the game. With something like Arma 2/3 that doesn't utilise many cores, there will be bottlenecking. With things like BF4, you will be fine as it can use all the cores.
Best solution is to switch to something like an i5 4690K if you can. Fewer, more powerful cores are a better option for games at the moment.
EDIT: That being said, you'll be fine in most situations. It won't be a huge difference most of the time.
A 4.5-4.7GHz 8320 running 2-way SLI GTX 970 is probably a case of borderline in a more CPU intensive environment. The bottleneck might cost you a few frames but whether there is a bottleneck or not you will still see a significant increase in FPS. If you get the GTX 970 SLI and find that GPU usage is not 100% when the CPU is nearing 100% then you could consider an upgrade to an I5 4690k or Xeon E3-1231v3.
WHAT!??!?!?!
Cause it got slow cores. Even haswell i3 can overkill it in some games. For GTX 970 it's terrible choice.
Get i5 if you're on budget, if not get i7, which is superior to i5 & any AMD CPU, & which gonna please you in everything starting from games finishing to renderings.
http://www.xbitlabs.com/articles/cpu/display/core-i3-4340-4330-4130_5.html#sect0
Get i5 if you're on budget, if not get i7, which is superior to i5 any AMD CPU, which gonna please you in everything starting from games finishing to renderings.
You must be missing out on the fact that he said that he would OC the 8320 to 4.5-4.7GHz, 8 cores at 4.5GHz, I think that would be able to compete with 4690K.
Barely competing, but still gonna lose, cause you can OC 4690k too & it gonna eat that FX CPU in games.
I'm just upgrading and keeping the 8320. Going to buy a single 970 then maybe buy the other 970 if I've already save up some money for an i5. Sounds good?
That being said do you think even with only one 970, will it be bottlenecked?
Not at all. A single card will be handled without issues.
Even with single 970 8320 still gonna bottleneck in some heavy CPU intensive games. I can show video where GTX 780 is being bottlnecked by 8350 in BF4 if you want. However if you gonna upgrade CPU to intel, then it will be okay.
No not really. SLI works better on AMD 990 chipsets than it does on Intel ones, hilariously.
With that sort of overclock you're absolutely fine. Sure you'd see higher if you had a hex core Intel but they cost the earth and then some.
I ran GTX 670s in SLI on my 8320 @ 4.7-4.9 (I have profiles) and saw no ills. I now run a 7990 in there as it's smaller and easier to cool.
Area 51 2014. Intel 5820k@ 4.4ghz. MSI X99.16gb Quad channel ram. AMD Fury X.Asus RAIDR.OCZ ARC 480gb SSD. Velociraptor 600gb. 2tb WD.
basically one card it will be fine, with 2 cards you might only be getting 90% of the second, but i imagine it will be fine,
yes but thats the case with anything that is cpu heavy, in games that arent though it should be fine
Okay, you're drifting off into 4690K vs 8320. The base still stands that an OCed 8320 will yield, little to no bottlenecking. I haven't heard of one such situation in which someone has complained about their 8320 being too slow for games.
Here, post of @Faa clears everything very easily with those videos:
http://linustechtips.com/main/topic/150288-fx-8320-or-i5-4570-help/page-4
OP the FX would bottleneck the cards badly at 1080P but if you go with such a display setup NO they will be totaly maxed out so your CPU will be fine...970's SLI will give you good performance on a single 1440P around 60FPS in most games with your current CPU.. 1440P panels as twice the pixel count of a 1080P...
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
Guest
