GTX 760 2-way SLI vs. GTX 970?
970, it is always better to run a more powerful card instead of two weaker cards. Remember not all games support SLI and/or Crossfire.
But OP already has a 760. SLI usually isn't recommended for buying an entire new system outright.
OP I would just buy another 760 and call it a day if you're looking for performance. You did say that temperatures were getting hot in your room. In this case, I'd likely recommend a 970, but don't expect temperatures to be dropping that much, if any, even with liquid cooling.
Liquid cooling isn't a magical witchcraft, all the heat taken away from the CPU/GPU goes right back into your room anyways, unless you mount the radiators externally.
970, that way you can SLI it down the road.
This is exactly what people probably told him when he bought his 760.
