Best 60hz IPS Monitor
The Robot
I have been looking at different monitors to purchase for my upcoming build, and would like some advice. I am looking at a 60hz IPS monitor around $200. I found the Dell P2314H for $155 and the Asus PB238Q for $200. What monitor do you guys recommend.
-The Robot
P2314H is not really recommended as it has BGR pixel arrangement and that can cause problems. P2414 and U2414 however are excellent.
Asus PB278Q or Dell U2414H
EDIT: Nevermind, i didn't notice your budget. Asus PB238Q would be a good choice.
The dell's price is 100 dollars over and the asus is not even close to the budget.
-The Robot
Thanks these both look amazing.
-The Robot
Not all of them do, Dell switched the panel, so there are both BGR and RGB versions floating around.  The ones manufactured in November 2013 or prior to that are BGR, all the once since then are RGB.
Well that's even worse isn't it?
