Help me with my homework / mini program
Can anyone find the error?? When I compiled something was wrong with the string.
This is in java. Program used JGrasp. Program is currently in WIP
public class AllenDengHw1D
   public static void main(String[] args)
      //Sides and additions of sides
      double sideOne = 3.3 ;
      double sideTwo = 4.4 ;
      double sideThree = 5.5 ;
      double sideOneAndTwo = sideOne + sideTwo ;
      double sideOneAndThree = sideOne + sideThree ;
      double sideTwoAndThree = sideTwo + sideThree ;
      if (sideOneAndTwo > sideThree && sideOneAndThree > sideTwo && sideTwoAndThree > sideOne);
         System.out.println("The sides length " + sideOne  " ," + sideTwo  " ,and "  + sideThree " make a triangle.");
The homework problem .  The triangle inequality theorem in mathematics states that the sum of any two sides of a triangle MUST be greater than the third side. The program will create three decimal variables representing three sides of a potential triangle. It must then check all possible combination to make sure that it passes the triangle equality.
LTT CSGO SERVER! IP 8.12.22.45!~  Connect by connecting on csgo console
Use console command "connect"   --->  connect 8.12.22.45
https://linustechtips.com/topic/212973-help-me-with-my-homework-mini-program/
System.out.println("The sides length " + sideOne +  " ," + sideTwo +  " ,and "  + sideThree + " make a triangle.");
Missing three '+'.
EDIT: Lightz beat me to it.
TrinityFX
CPU: i5-4440 @ 3.1Ghz RAM: Crucial 1 x 4GB @ 1.6Ghz  MOTHERBOARD: MSI Z87-G41 PC Mate GPU: PCS+ HD 7870 Ghz Edition | CASE: NZXT Source 210 Window | HDD #1: Toshiba 3.5" 500GB HDD #2: Toshiba 2.5" 500GB PSU: Cougar SL500 OS: Windows 8.1 Pro
 | https://pcpartpicker.com/b/2wccCJ |
System.out.println("The sides length " + sideOne  +" ," + sideTwo  +" ,and "  + sideThree +" make a triangle.");
Interesting. Before I made the thread, I tried compiling the program with that in the string, yet it failed on me. O_O
