What's the step after the 4790k? My friend is gonna build a new computer and he wants more power than me! What's the next level? The pc is mostly used for productivity, professional video and 3d rendering, and for hobby gaming.
OS: Windows 10 - Kubuntu 15.10 - Mac OSX El Capitan  CPU: i7 4790 @ 4.00GHz  MOBO: AsRock H97M Pro4  RAM: 4x 8GB Kingston HyperX @ 1866MHz  GPU: VTX3D R9-280 X-Edition  CASE: iTek Spacebox w/ Arctic Fans  PSU: Corsair X750M  SSD: 250GB Samsung 840 Evo  HDD: 3TB Western Digital WD30EZRX  DISPLAY: 3x Acer P193W  MOUSE: 5$ Chinese  TOUCHPAD: Logitech T650 Touchpad  KEYBOARD: Perixx Px-5200 w/Mx-Blues
https://linustechtips.com/topic/207764-better-than-4790k/
5820k
then 5930k
then 5960x
https://linustechtips.com/topic/207764-better-than-4790k/#findComment-2818422
Nothing on LGA1150, you have to go 2011 now. Recently Intel released Haswell-E, which is 5820K, 5930K and 5960X. Those, however, require X99 motherboards and expensive DDR4 memory. You might still be able to find Ivy Bridge-E, which is the last generation and is 4820K, 4930K and 4960X.
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/207764-better-than-4790k/#findComment-2818481
Xeon and the i7 (Extreme) are almost the exact same.
An i7 4790 is the same as the Xeon E3-1276 v3.
You may watch this video. I learned about i7's and Xeon's from it.
They're not exaaactly the same. One allows ECC memory and the i7 has a more advanced iGPU.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/207764-better-than-4790k/#findComment-2818507
I never said they were "exaaactly the same." I said they are almost the exact same. ;)
You didn't use the word almost ;)
https://linustechtips.com/topic/207764-better-than-4790k/#findComment-2819010
There is your answer. I believe HardwareCanucks recently made a video where they showed the build of one of their video editors' rig. It has a 2011 CPU, high frequency 32GB of RAM, TITAN Black... - all that good stuff that you gotta sell your liver in order to afford.
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
https://linustechtips.com/topic/207764-better-than-4790k/#findComment-2824082
? Check your own post. The quote even had it on that. You might wanna be more vigilant next time. ;)
Ermm...
The first line and second line are two different statements, as you're comparing two different products.
I don't see the word almost present anywhere in the second line.
https://linustechtips.com/topic/207764-better-than-4790k/#findComment-2824296
Ermm...
The second line I thought you meant the first one.
Clearly, OP wanted to know if there was a CPU that was better than the i7 4790K.
You suggested the Xeon, so I gave you an example of the i7-4790 and the Xeon E3-1276 v3. Figure of speech, I'm comparing both CPU's in terms of raw performance. iGPU and ECC memory are the only different features of the CPU itself.
I was only suggesting that to explain how the Xeon is NOT better than an i7.
https://linustechtips.com/topic/207764-better-than-4790k/#findComment-2825843
