How fast would a normal SATA SSD be if somehow hacked to work with PCI?
Solved by KemoKa,
Impossible unless you are using M.2 SSDs. Plextor's SSDs are just passthroughs for an M.2 card, and those operate over the PCIe bus anyway.
Everything depends on the controller. If it is a SATA controller, it's limited to SATA III, and if it is a PCIe controller... well, it will be in a PCIe slot.
Sorry to disappoint...
Featured Topics
Xrniu ·
7
3
bleedpurple ·
Posted in Storage Devices2 -
geoffery ·
Posted in Troubleshooting1 -
IPQ ·
Joey__ ·
Posted in Troubleshooting5
