uuuuuuuhhhhhh, what are abs?
CPU: Intel Core i5 4460 | GPU: XFX r9 280x DD BLACK OC EDITION | RAM: 8gb Kingston HyperX Fury 1600Mhz | Mobo: Gigabyte h97n-WIFI | PSU: EVGA 600B | Case: Cooler Master Elite 120 | Cooler: Stock intel | SSD: Samsung 840 EVO 120gb | Storage: WD 150 gb
CPU: Intel Core i7 4710MQ | GPU: NVIDIA Geforce GTX 850M | RAM: 8gb Corsair 1600Mhz | Mobo: Metabox WA50SJ Motherboard | Case: Metabox WA50SJ case | Cooler: Stock | SSD: Sandisk 256gb
:wub:  :wub:  :wub:
Best purchase this year, bcuz forza
https://linustechtips.com/topic/201430-abs/#findComment-2730563
https://linustechtips.com/topic/201430-abs/#findComment-2730573
hmmm i guess u need to take your car to have it serviced
ABS is very important when braking
locking brakes are no fun. Especially when its getting cold
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/201430-abs/#findComment-2730595
snip
oooohh, those things. They require you to go outside, I don't like that server.
:wub:  :wub:  :wub:
https://linustechtips.com/topic/201430-abs/#findComment-2730605
Hey there guys, I was just wondering, why do my 2 Right abs look so weird, while my 2 Left abs look normal? Yes i only have 4, but why do the left ones look normal, but right ones look slightly curved or something?
Not all abs are symmetrical, most aren't.
https://linustechtips.com/topic/201430-abs/#findComment-2730643
This can generally be caused by masturbation on a preferred side.
the-dangers-of-masterbation_zpsc5bc7e12.
https://linustechtips.com/topic/201430-abs/#findComment-2733645
No. You have eight. The rest of them are just not visible.
You're probably wankin' with your right hand :P
uuuuuuuhhhhhh, what are Tabs?
Fixed that for you :P
ヽ༼ຈل͜ຈ༽ノ raise your dongers ヽ༼ຈل͜ຈ༽ノ
It feels as though no games ever leave the BETA stage anymore, until about 3 years after it officially releases. - Shd0w2 2014
https://linustechtips.com/topic/201430-abs/#findComment-2733921
Sipping semen will give you bigger abs :D
strange...@beebskadoo tells me he is fat..
https://linustechtips.com/topic/201430-abs/#findComment-2734072
i think it's approved by Clarkson, the tinier your sausage is the more you sip semen  :blink:
So...@beebskadoo must have a massive gentleman's sausage...
Because sipping semem makes you have abs and Beebska is fat.
https://linustechtips.com/topic/201430-abs/#findComment-2734153
Anti-lock brake system, duh.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/201430-abs/#findComment-2734163
