cosair power supplie
Go to solution Solved by ray946,
750W is way overkill for this system. A single 4790 and 280X could run no probs on 500W. @Aniallation There's something people often misunderstand. Overkill doesn't mean your system will suffer, only your wallet (or possibly efficiency if low enough).
ray946, you could save a little and get an RM550, or you could look for a Seasonic G Series or S12G Series 550W, XFX XTR 550W, Rosewill Capstone-550-M, Cooler Master V550S, or one of several others.
Thanks for your help i will go for the rm 550 and again thanks ????
Hi Guys
               Just asking would corsair rm 650 watts would be ok for the follwong items to run
1  AMD 280x graphic card
2  7 noiseblocker fans 120 pmu
3  asus m/board z97 pro
4  I7 4790 cpu
5 plus a full custom water cooling with 2x radiater  and pump 18v 600pm
There is No optical drive
Please advice
https://linustechtips.com/topic/200026-cosair-power-supplie/
It would be okay, but the RM aren't necessarily an amazing line of supplies. What is the budget?
https://linustechtips.com/topic/200026-cosair-power-supplie/#findComment-2711427
Hi Guys
4  I7 4790 cpu
Please advice
Yes. There is a sticky for this.
Personally though I wouldn't get the RM. Get the EVGA 750 G2
"Rawr XD"
https://linustechtips.com/topic/200026-cosair-power-supplie/#findComment-2711433
https://linustechtips.com/topic/200026-cosair-power-supplie/#findComment-2711477
750W gives a bit of headroom, and the EVGA G2 is the PSU to get right now pretty much, being a Super Flower made unit. I never said that 750W would be required, I said that I'd take the 750G2 over the RM650, as there is no 650G2.
"Rawr XD"
https://linustechtips.com/topic/200026-cosair-power-supplie/#findComment-2711498
Yup it is perfectly fine.
https://linustechtips.com/topic/200026-cosair-power-supplie/#findComment-2711569
https://linustechtips.com/topic/200026-cosair-power-supplie/#findComment-2711595
That reminded me to post on EVGA's forums. Here we go http://forums.evga.com/My-suggestions-to-EVGA-m2205456.aspx
https://linustechtips.com/topic/200026-cosair-power-supplie/#findComment-2711744
