Nicest Build possible
Go to solution Solved by KPZ211997,
This is the rig
CPU: Intel Core i7-4930K 3.4GHz 6-Core Processor  (£391.14 @ Aria PC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  (£79.99 @ Amazon UK)
Motherboard: Asus Rampage IV Black Edition EATX LGA2011 Motherboard  (£335.75 @ Scan.co.uk)
Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive  (£173.59 @ Aria PC)
Video Card: EVGA GeForce GTX Titan Black 6GB Superclocked Video Card (4-Way SLI)  (£779.50 @ Ebuyer)
Optical Drive: LG UH12NS30 Blu-Ray Reader, DVD/CD Writer  (£39.48 @ Ebuyer)
Monitor: Dell U2414H 60Hz 23.8" Monitor  (£167.94 @ Aria PC)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard  (£234.00 @ Amazon UK)
Mouse: Razer DeathAdder Wired Laser Mouse  (£45.84 @ CCL Computers)
Speakers: Logitech Z506 155W 5.1ch Speakers  (£55.00 @ Aria PC)
Total: £6686.28
Generated by PCPartPicker 2014-07-29 17:22 BST+0100
Mini ATX NAS for mass storage
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard  (£54.94 @ More Computers)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  (£65.18 @ More Computers)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (£36.81 @ Amazon UK)
Total: £909.74
Generated by PCPartPicker 2014-07-29 17:26 BST+0100
P/S: 4 titan blacks >>>> 2 titan zs
Spend the rest on a vacation or something
ok, so I was wondering if you could help?
I have a £12,000 (Twelve Thousand) budget and I am tring to build the best Gaming/ editing build possible this budget is with peripherals as well. I want it to have a case without a side panel and good cable management systems and look very sleek and minimalist has to be an i7 processor :)
EDIT: Would it be woth buying 5TB in SSD's if I have them all on RAID or whatever and also what water cooling method would begood as well as the nicest cases out there or a place that do custom ones?
EDIT: This is also with monitors btw possibly decent refresh with 3 togther I have a 50" 3D TV to go above them so reasonable size
EDIT: Here is what I have so far would this work as a build? http://pcpartpicker.com/user/AsaButterfield/saved/72vqqs
https://linustechtips.com/topic/188483-nicest-build-possible/
12000? Don't you mean 1200?
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537679
I think an i7 might be just a littttttlleee bit out your budget.
"The only person you are destined to become is the person you decide to be."
CPU: Intel i5 4690K - Motherboard: Asus Maximus VII Ranger - RAM: Corsair Vengeance LP - 2x4GB @ 1866Mhz - GPU: MSI Twin Frozr GTX 770 4GB - CPU Cooler: Be Quiet! Dark Rock Pro 3 CPU Cooler - PSU: EVGA SuperNova G2 750W - Storage: Seagate Barracuda 2TB HDD- Case: Fractal Design Define R4 Windowed (with Red AKASA Led Strips) - Display: Benq GL2460HM 24" Monitor
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537680
I7 4930k SLI titan Z a caselabs case alot of WC and all the other expensive stuff on internet
Yeah but sometimes just going with the expensive stuff sometimes ther are a ot bett things tat are a but cheaper I am new to all this only ever built 1 rig before
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537708
Build a desk and put a dual sli titan z, Xeon, what everboard you want and an ethiopian orphan inside. Ther that is your new dream setup :D
[spoiler=My Beast Rig Damocles]Case: Coolermaster Storm Stryker Motherboard: Asus x79 deluxe CPU: Intel I7 4960x @3.6GHz (soon to be oc) RAM: Kingston HyperX 64GB @2400MHz GPU: Nvidia Geforce GTX 770 (Gigabyte) @4GB PSU: Corsair RM1000 Fully modular CPUCooler: Corsair H100i Watercooling Storage: Seagate 2TB SV35.6 SATA 6GB/s 7200RPM 64MB 3.5"   x2  Sound: Creative Soundblaster ZxR sound card
This is my old pc which I am reamending to be a media server or a nas. Motherboard: Generic fujitsu CPU: Intel pentium G640 @2.8 GHz RAM: 4GB generic fujitsu memory PSU:  CPUCooler: Stock intel cpu cooler Storage:  Fujitsu MHZ2120BH @120GB, Soon to have a HDD for more storage.
_ASSASSIN_ Jerakl
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537713
This is my favourite all around build to date. It's just really solid: http://uk.pcpartpicker.com/p/y6hfnQ
Spend the rest of the 10,000 on something else :)
EDIT: Maybe get a GTX 780 ti instead of 780, but to don't need to spend more than this on a computer.
CPU: Intel Core i7 4770 | Motherboard: Asus Z97-A | RAM: 8gb (2x4gb) Corsair LP @1600mhz | GPU: Asus TUF GTX 1660 OC 6GB | Case: Fractal Design Define R4 | Storage: 250gb Samsung 840 EVO and 1TB WD Black 7200rpm | PSU: Corsair CX750M | Display: Asus VG245H 1920x1080 | Cooling: Cooler Master Hyper 212 EVO and default case fans | Laptop: Early 2015 13" Macbook Pro Retina - i5 2.7Ghz - 256GB SSD
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537717
Unless you are planning to do the most complex stuff in the world (Which means SLI Quadro/CF FirePro etc) it is obvious you have only ever build 1 rig before. Give us a list of programs you're planning to use and what exactly you are going to do because 12000 is just serious overkill and wasted money.
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537756
That is a pretty hefty budget, although I wouldn't advise spending £12K on a pc.
When you say case without a side panel, do you mean a non windowed case ?
Do you need CUDA support for the programs you use ?
Do you need a monitor ?
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537777
The best of the best:
http://pcpartpicker.com/p/dr7VmG
the storage use what you want, i would go for a samsung 840 evo...
The best for the buck:
http://pcpartpicker.com/p/jm8Gbv
I know is a bit overkill, and not exactly the best of the best for its cost, but is a really high end build, and way more optimized than the first one...
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537779
http://uk.pcpartpicker.com/p/vWX8bv
I think i went overkill but who cares (if you change the SSD with something normal you can make something Nice)
cpu ?
£10K on an ssd is insane.
£5K on gpu's is also pretty insane
You don't need to waste money on components like that.
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537785
This is the rig
Total: £6686.28
Total: £909.74
My current rig for entertainment/gaming: i5 4570 3,2GHz; MSI B85M-E45; ZOTAC GTX760 AMP!; 8GB (2x4GB) by Kingston; Seagate Barracuda 1TB 7200rpm; Corsair 200R, Corsair VS650; Dell U2312HM, Samsung DVD R/W optical drive; CM Devastator; Corsair MM400 gaming pad
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537823
Ilike this build but the case is not very nice and the mouse is horriable hahaha
You can choose the mouse that you prefere more, and the case too, just do a bit of researches on google, they were only to fill the blank spaces...
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537872
That cpu is not worth the money imo. Are you doing extreme video editing ?
Do you need CUDA support for the software you are using ? or does it support OpenCL ?
The 850 Pro SSD is nice, but totally overpriced. I would suggest the Samsung Evo.
For 3 x 1080P monitors then 290X crossfire or 780 ti sli would be enough. Obviously if you want the 3D feature then you need Nvidia gpu's. The Titan black is no better than the 780 ti for gaming.
Do you really need 64GB Ram ? Seems massive overkill to me.
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537913
We have to use the Intel I7 for work :/
I'm not asking about your processor, I mean't graphics acceleration.
Do you use CUDA or OpenCL?
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537922
Yes it would, i would suggest to buy the single parts of the water loop instead of the swiftech (is pratically the best on the market, but it cant do better then a custom loop). The 850 series are pratically the best ssds for now, they are just appeared on the market, but i would go for the 840 evo, they are amazing and amazingly cheap...
https://linustechtips.com/topic/188483-nicest-build-possible/#findComment-2537925
