i have 2 780tis and i wana do a triple monitor surround. how do i do this i click surround and then apply and my screen go black but when they turn back on it hasnt enabled it yet.
if you are reading this you are wasting valuable time and should maybe rethink your life choices.
https://linustechtips.com/topic/178948-how-do-i-configure-surround/
your problem is that you are using Internet Explorer
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
This is how I set mine up. First, make sure all the displays are active. Like this:
Then have them connected like this and click apply. It should then give you some options that are pretty straight forward.
thats exactly what a did bbut
it doesnt want to work
Titan Blacks? Adopt me, I can cook good food.
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
ok how are the monitors connected?
are they like iSaeko's?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
<pic>
<pic>
Y U HAVE 3 SCREENS ON 1 AND ONLY 1 SCREEN ON OTHER?!?!
1 on display port and 2 on dual link dvi they are 1440pmonitors
try swapping the connections from one gpu to another gpu
I have two cables connected to one screen. It allows me to switch surround on and off without having to move cables.
Right now I have all three connected to one card, but I have to connect one of them to the other card if I want to use surround with SLI.
Do you have issues?
You can connect the screens to either GPU. SLI just makes the GPUs work together.
ahh
Thanks for your help! i managed to fix it by doing a complete driver reinstall. now i have 3 32inch monitors all at 1440p glory !!!!
good for you bro enjoy your three screens epeen
