Water Cooling Pump Guidance
Solved by airdeano,
welcome to the Linus Tech Tips forums!
for a simple, never going to upgrade cooling loop, the XSPC 750 is a fine pump. but if
looking to include a GPU in the future, then that pump isn't really sufficient for multi-block
applications. then come the DDC or D5 pumps. if in the future your adding a GPU to the
loop, the DDC (MCP-35x) or D5 will easily accommodate the multi-block usage.
the 7/16" tubing on 1/2" barbs is an excellent choice.
