How to do monitor shopping
Solved by CaptainRagu,
- Higher contrast ratio makes the blacks seem blacker and the colors seem more vibrant.
How many colors it can display, as well as how easy it is to adjust colors will result in better color reproduction.
The brightness is how bright the backlight can be. This is really preference.
Lower response time is better. For normal work anything around 10 ms is fine. For gaming people look for 2-5 ms. The lower the better as you wont get image tearing and streaks. It will often say grey to grey (GTG) which is what youre looking for.
Screen size and adjustability is again preference based. If you plan on running 2 or more monitors in tandem, people will often look for monitors with slim bezels.
In my experience brand seems to play little role. Good brands will sometimes make shitty monitors and lesser known brands will sometimes have a great budget monitor. Ratings and reviews will tell you whats best.
