Should i wash my fans?
staman96
Hello! I saw two minutes ago the techquickie's video about fan bearings....i was always washing my fans to get rid of dust and now i wonder if that was right.....so should i continue washing them?
Thanks...
No fan has died yet....
...what kind of washing are we talking about here? Like, with water and soap?
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
no soap.....just washing it under the fauset....i wash the bearing and the blades and then i blow the water off....
If you're completely drying it immediately after it's wet then the bearing wont' rust and it's fine. The bearing will need to be re lubricated though because you are basically washing away the lubricant. Why are you using water in the first place? Why not just clean your fans with compressed air? Or even just have filters and your fan stays clean and just clean the filter?
get a old shaving brush to clean them with, DRY!! at best, use baby wipes or the like.
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
I wash the blades of without getting the bearing wet. I would not recommend getting the pcb on the fan wet,
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
then i'm going to lubricate the bearings....what kind of oil should i use?
IMO, the only thing you should be doing to your fans is wiping the blades. Fans will last a long time without having to clean the bearing, unless yours die prematurely.
Eh, anything like WD-40 would do.
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
Lol don't wash your fans ha, just blow them to get rid of the dust.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
