MSI GTX 770 Gaming Water Cooling
LDG
Hi.
Anybody here has water cooled the card stated in the title aside from the solutions provided by KRAKEN.
Thanks for any suggestions..
i9-9900K || MSI MPG Z390M GAMING EDGE AC || Gigabyte RTX 2080 Super Gaming OC || 16GBCorsair Vengeance LPX 3200Mhz || Samsung EVO 970 Plus Samsung 850 EVO 2TB + Crucial BX100 500GB + 4TB HGST NAS || Factal Design Define Mini C TG || Corsair RM750x || Corsair H100i Pro RGB || Acer Predator XB271HU
Not sure what the question here is. You just want to know if anybody has water cooled a GTX 770 and that's it?
Yes. specifically the gaming edition by MSI.
Well, I'm sure it could be done with no problem.
I don't think anyone makes full blocks for the 770.
correction
EK do have waterblock for GTX770
http://www.ekwb.com/news/352/19/EK-introduces-GeForce-GTX-770-water-blocks/
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
I should have clarified.. No one makes a full block for the MSI gaming 770.
fair enough
Hi.
the only solution is getting the Corsair HG10 mount and any AIO watercooling unit which uses the Asutek design
