Need microphone loopback (without latency)
I found my answer. From what I see in this video I can plug in my 3.5mm microphone and my 3.5mm headset into the desired inputs on this mixer and I will hear microphone loopback through my headset.
but how will you get audio to the program you're using to chat? Because the way I see it that mic input can be either a passthrough or it's a channel in for the mixer but you need both. The passthrough so your friends can hear what you're saying and an input channel so you can hear it through your headphones. As for will it improve your sound quality? That would be a no if you're talking about the actual sound. As for delay times I am not sure.
Since I have those two inputs into the mixer it would go to my computer through a USB, hence I would hear sounds from my computer and my own mic loopback.
