Sound Card Options for 125$
SKOONJar
I've been looking into sound cards and then realized I have no idea whats good so I figured I would ask you guys. I listen to music a lot I mean a lot and game. Music sound is more important to me I listen to it for hours a day through my pc coming though my stereo in my room( yes 2.0 set up but I want upgrade options up to 5.1 or even 7.1). I have a set of Cerwin Vega bookshelf speakers that everything will come through. My headset is a usb headset with a built in sound card so no worries there. My budget is 125USD. I heard Creative cards are only good for gaming but correct me if im wrong but I heard asus cards are all around great.
PC Specs: CPU: Intel i7 4770K / CPU COOLER: Corsair H100i / Storage: Samsung 840 EVO 120Gig and Seagate Barracuda 1Tb / Motherboard: MSI Z97 Gaming-7 / GPU: EVGA GTX 780 SC ACX / Power Supply: SeaSonic M12II 850watt / Case: Corsair 750D 680 Coaster
I have the xonar STX and it's great but it's around $200
The Xonar dgx will give you 5.1 at $50
The Xonar DX will give you 7.1 at $90
either of those will be an improvement over stock.
I've never had much luck with creative cards so I avoid them and I found the ASUS control panel is quite good.
Hope that helps some.
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
Hows the music quality with your stx?
I'm thinking of getting the DX for a 2.1 system. (H/K Soundsticks). Would that improve sound quality over stock mobo audio
For 90$ I sure hope it would do something...
Any other ideas?
The music quality on the STX is a lot better than the other 2 due to its onboard Burr Brown DAC. keeping in mind, you have to have a decent set of headphones or speakers.
Well my cerwin vegas are very nice.
Music quality is very nice but I'm also using Grado Prestige series phones with it.
You have to have the hardware to make use of the signal, like Josh_05 said.
Nice choice on the Grado's :) I'm using the SR225i's and love them :)
Your Cerwin Vegas will defiantly benefit from the STX's DAC :)
I scored a set of 325s a few months ago, older model, but not even used. So good.
