Starting over... how can I completely reset my PC?
Factory reset and select remove everything?
current PC:
PC configs I used before:
4 minutes ago, James Jonathim said:
I have a PC running Windows 11 and I just want to basically wipe it completely of all files, apps, settings, and drivers and start completely fresh.
do you have disk/USB from Windows? if you bought the official version of windows?
current PC:
I have the official Windows 11 home. I purchased the product key or whatever when I built my PC. It should save on my account, correct? Is there a way to check before doing it?
Well, if you have the key, like a code or whatever, it either saves on your account, or you can just type in the key again while activating.
You can also skip the Windows activation and activate it once it's fully installed/updated.
10 minutes ago, James Jonathim said:
How should I back them up?
You want to wipe all data and now you're asking how to back up the important data?
current PC:
