Are these parts good?
Solved by Hinjima,
14 minutes ago, PatRed said:Is the Asus TUF GAMING B650M-PLUS WIFI a good motherboard for a Matx build? Also Should i go for the asus tuf or gigabyte gaming rx 7800 xt model?
Here's the complete build-https://fi.pcpartpicker.com/list/kLqV89
Very good build The AIO is overkill but if you want an AIO with RGB this is a good option!
I use the ASU TUF B650 PLUS WIFI with my own 7700x and its been rock stable since October 2022, no issues at all.
You got good RAM speed and a decent power supply.
There won't be any noticeable difference betwee nthe ASUS TUF or Gigabyte Gaming RX 7800 XT. Take the one you like the most.
